New cover painted and installed (not as pretty as the polished one but I'm not paying for that right now). Managed to run the bike for a few minutes last night for a leak check, but it needs the carbs synched again after all this work and probably some tuning for the 650 cam and increased compression.
One annoying thing, when I fired it up for the first time it was only running on 1/4. This was a solid running bike when I did this topend work and nothing should have changed in the ignition. Checked for 12v at the coils, checked for 12v at the points, didn't find anything wrong but the timing light confirmed I had absolutely no spark on 2/3 after running it for a few minutes. Left the light hooked up and decided to fire the points manually with a screwdriver while I fiddled with things. First time I opened the 2/3 points with the screwdriver they fired (and lit off a bunch of unburned fuel in the pipes lol) and after that the bike ran fine. I guess they were hung up somehow, but I can't figure out how. I'd like to make sure it doesn't happen out on the road?
