Author Topic: Saddlebags for a CB550?  (Read 2689 times)
Offline andrewmundy
« on: March 20, 2021, 04:53:31 PM »
I've been trying to get a good idea of what sort of saddle bags or panniers I can attach to my bike. There isn't a whole lot of information or details on this topic but I'll see some cool hondaline saddle bags and dream of what it would be like to have something similar on my bike. So heres my question. Are the mounting points for a rack in a standard position? Like, could I find mounting hardware for a 750 or even a GL and easily attach that to my bike?
Looking for something like this
Ive found some mounting hardware that could work here
and some of those panniers here
Does this look like it could possibly work? Also, does anyone else have any recommendations? Ive been having a hard time getting some good info on this and I'd hate to spend a grip of cash just for things not to fit well. Any and all info is very much appreciated, thanks!
74 Honda CB550f
72 Honda CL350
Offline jorvaljr
Re: Saddlebags for a CB550?
« Reply #1 on: March 23, 2021, 05:36:04 PM »
I saw this video on youtube. This guy might be selling his.
Online low-side
« Reply #2 on: March 24, 2021, 02:45:48 PM »
I don't know if mounting hardware for a 750 would work, but I'm certain that hardware off a GL wouldn't without significant modification.
Offline river
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
« Reply #4 on: March 25, 2021, 02:28:15 PM »
Mount locations for shocks and spacing of foot peg mounts on frame and the rear fender as well as the turn signals and the width of frame/seat all are radically different on cb750 vs cb550/500.
Width of bikes makes a difference when you see that most panniers for hard cases tie one side into other with tube that connects near taillight or behind license plate.
So, if you have the originals and fab up a mockup of thebends and twists with 1/4" copper tubing, easy to form, you can use it to make patterns or as a guide when bending or welding up brackets to adapt your rack mounts to the bike.
Then you have to find someone who is a good mig welder or tig welder if making new frame from hard aluminum rod or square tubing.
Then if dealing with Chrome tubing for frame you have to re-chrome or stop rust from eating the modified frame...
The Shoei bags and frames for a 550 are out there but the cult like following will cause you to pay dearly for them.
If you go with soft bags you need to build or install things to keep bags out of the rear wheel and chain and stabilize the bags.
If you want funky, find a vintage set of Vetter hard saddlebags.
You can harvest the mount points off the Goldwing theytypically come off of after building a frame to bolt them to so you can build your replacement mount frame for the 550/500 frame.
BTW, swingarms for 550F and frame for 77-78bikes are different ... So, don't be disappointed if you find aset from a 550k from 77-78 and then they do not fit your 74-76 k. Shock locations are identical but, foot peg mount method changed, don't know if they moved the position.
Offline andrewmundy
« Reply #5 on: March 25, 2021, 06:34:05 PM »
All really great info and exactly what I was looking for. Thanks for sharing!
74 Honda CB550f
72 Honda CL350
« Reply #6 on: March 25, 2021, 07:16:50 PM »
 Many of the more inexpensive bags / accessories came with universal brackets that had multiple holes or slots. I had a cb400f rack on an early cb750k, it fit great.
« Reply #7 on: March 25, 2021, 07:30:22 PM »
Offline andrewmundy
« Reply #8 on: March 26, 2021, 10:30:37 AM »
https://photos.app.goo.gl/YMtoxbaPUWQzpWU87
 I have these.
These look great! Can you share any info you have on em?
74 Honda CB550f
72 Honda CL350
Online newday777
« Reply #9 on: March 26, 2021, 12:07:58 PM »
