Author Topic: CB650C turning over but not starting  (Read 519 times)
anthograham
« on: March 20, 2021, 12:32:10 PM »
MOTORCYCLE:  81' CB650 Custom
I'm hoping someone on here can help me figure this out. I've spend the past 3 months overhauling my 650 with the largest changing being the installation of a M unit. The ignition system has remained the same all except for the b/w wire going to the coils getting power from the munit rather than the start circuit like OEM. However, when I try and start the bike, all that happens are a few backfires and pops.
What I've done:
I've checked every plug to make sure they are firing, which they are.
I did not run a compression test but all the cylinders are going through their strokes properly.
Fuel is getting to the cylinder.
The only thing I can think of now is that my timing is 180 off. However, I did switch the yellow/blue wires going to the coils to the opposite side but this did not make any difference.
Any and all help is GREATLY appreciated. Once I get this sucker started it's ready to ride.
Thanks,
Re: CB650C turning over but not starting
« Reply #1 on: March 20, 2021, 03:40:54 PM »
A spark out of the cylinder does not guarantee one under compression and 650 are quite notorious for ignition units leaking black goo and failing
« Reply #2 on: March 22, 2021, 08:13:16 AM »
You cant bypass the ignition units and the only test i know of is sustitution
