Author Topic: Which Dyna ignition?  (Read 807 times)
Offline newday777
« on: March 23, 2021, 01:33:38 PM »
Which of the Dyna ignition was the bad failure rate model? I've read of failure by some but don't remember which ones....
I've seen a set of nos Dyna S offered and don't want to buy the wrong one. Going on a 74 CB750.
« Last Edit: March 24, 2021, 05:55:54 AM by newday777 »
Stu
My current rides
Prior bikes....
Re: Which Dyna ignition?
« Reply #1 on: March 23, 2021, 01:40:46 PM »
It was up here, Scottly know. My Dyna-S newer model than the failing.
http://forums.sohc4.net/index.php?topic=83748.msg2136019.msg#2136019
Offline newday777
« Reply #2 on: March 24, 2021, 05:58:29 AM »
I'm still unclear from that link or your "My Dyna-S newer model than the failing. "
Stu
My current rides
Prior bikes....
« Reply #3 on: March 24, 2021, 07:46:09 AM »
My model was the newer Dyna-S. OK
The previous model reported with a bad batch as I understood it.
Here photo of mine, purchased 2014.
Edit:
I should not buy that old, not cheap kit. It might be faulty.
I guess it can be the failing version.  3ohm coils?
I trust this more.
https://www.ebay.com/itm/Electronic-Ignition-Kit-Honda-CB750-1969-1978-w-5-ohm-Coils-NGK-Resistor-Caps-/184670878776?_trksid=p2349624.m46890.l49292
I paid not much more than $110US + shipping for my last set of Dyna 5ohm coils, eBay USA.
There are kits with Dyna-S and 5 ohm coils (black) on eBay.
Dynoman has too.
« Last Edit: March 24, 2021, 08:38:34 AM by PeWe »
Offline newday777
« Reply #4 on: March 24, 2021, 10:16:15 AM »
Thanks Per. I thought it was expensive and wasn't sure of it's being one of the possible bad units.
Stu
My current rides
Prior bikes....
