I purchased a 1973 CB500f 2 weeks ago. I rode it for a few minutes and then the bike died. Turns out my battery was low on charge, so I purchased a new battery and bike died again. The original rectifier and regulator are still on the motorbike.
So I read that there are 3 things to look into; Stator, Battery, Regulator/Rectifier. I immediately order 2 Regulator units from Amazon.
I started testing my stator according to the service manual (page 95) and got 1.0 Ohms resistance value. My coil was 5.5 Ohms resistance value. (manual values are 0.35 & 4.9)
I search youtube found a video (https:///youtu.be/BVXnbrigYf8) on how to check stator conditions. So I checked the continuity to ground making sure insulation are good. (set to Ohms, one probe to ground other probe to 1of 3 yellow stator wire) PASS. Next I check the resistance reading between all 3 yellow wires. I get a resistance reading of 1.0 Ohms between all 3 wires, which means there are no breaks. My understanding is my Stator and coil are good.
Moving on to the new regulators I purchased from Amazon. They both look the same from 2 different sellers. I unplugged the rectifier and attached 3Y, 1R, and 1G to the Regulator unit. Then I attach Red,Black, White from the old regulator to the new wires from the new unit (black to black, green to green, white to white)
Start the bike, voltage @ 12.9, rev the engine nothing no gains.
So this is where I am at, frustrated, called local shops and no one wants to touch this vintage Honda. I am searching this forum for solution atm, but I am exhausted and want to ride before the Summer is over lol. Any help would be appreciated.
Questions:
1. Are there any fuses on this motorcycle?
2. can someone please post a link on how to test the R/R units?
As a token of appreciation for any help I may receive from this forum, I will make a donation to the forum admin when my bike is up running. Thank you.
