I was told years ago that there is no substitute for cubic inches, and that’s hard to argue with, I remember years ago looking at a ski boat it had a blown Bbchevy, man it went, written on the Stern “powered by cubic dollars” and I think that’s about right too. OK I bought a 1976 Rickman CR750 duel seat with mags and Triple discs in 2005 and have been collecting bits ever since, I now have quiet a collection of old school hipo bits and pieces mainly R C stuff with some other bits, that I will build two engines with, One for the Rickman and another for a Amen Savior Chopper but what size? In the past I have had a few, a new K1 std, then kited it with an 836, then built a RC 970, and the Rickman came with a 1000 but it had serious oil leaks between the sleeves and I sold that engine, I have the following sets of pistons with barrels ready to go what do ya all think?
Std 736 cc 61mm, Ape 836cc 65mm, Venolia 850cc 66.5mm, Henry Abe 895cc 67mm, or MTC 1055cc 73mm. I have a range of cams like Norris RX2, Norris RX3, RC315, RC327, along with RC ported heads with big valves etc RC adjustable cam sprockets, messnermoto cam chain adjuster, RC golden rods and Yoshi Superrods lightened balanced cranks RC lightened flywheels, RC welded clutch hub Barnett clutches and under cut gearboxes, with a couple F1 solid output shafts. For carbs I have a set of Delorto DHLA40 carbs with 30 mm choke tubes and a set of 29 mm smoothbores. Thanks for your thoughts both engines may see the drag strip very occasionally but mainly street and I have a few bikes so they are not going to wear out!
