Author Topic: 1975 cb550f  (Read 8675 times)
Offline Oddjob
Re: 1975 cb550f
« Reply #100 on: November 30, 2024, 05:11:08 AM »
May I suggest mounting the light under the frame bar instead, if it fits of course. Reason being it's better protected and where you plan will get it hit by stones, water and other crap, won't take much to stop it working and you'll have no idea if it happens when you're riding, if that happens you risk a pull by the police or worse being rear ended by an inattentive driver. Both to be avoided at all costs.
Offline Fezzler
Re: 1975 cb550f
« Reply #101 on: November 30, 2024, 08:05:58 AM »
Thanks.  I appreciate the input.  I'll give it some serious consideration.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Fezzler
Re: 1975 cb550f
« Reply #102 on: December 01, 2024, 04:35:40 PM »
Always so controlling at the local bar.
Isn't it fun getting new control wires through old stock handlebars?
« Last Edit: December 01, 2024, 04:37:47 PM by Fezzler »
Offline Oddjob
Re: 1975 cb550f
« Reply #103 on: December 01, 2024, 05:10:41 PM »
No light switch on the us model mate? On the right hand switch gear that is.
I bought one of those as it was advertised dirt cheap for the 550 and it came exactly like yours. No use to me at all as we need a light switch, you could have had it for postage if I’d known.
Offline Fezzler
Re: 1975 cb550f
« Reply #104 on: December 01, 2024, 05:16:31 PM »
My '71 500 controls have a headlamp on/off switch.  My '78 550 does not.  Is it possible sometime between '71 and '75 all US required running headlamps for motorcycles so Honda eliminated the headlamp on/off switch in the USA?
Online newday777
Re: 1975 cb550f
« Reply #105 on: December 01, 2024, 05:47:47 PM »
Yes. On 1976 models onward
Offline Fezzler
Re: 1975 cb550f
« Reply #106 on: December 06, 2024, 10:05:45 AM »
Chain
Seat fastener tabs (now painted black).
Offline calj737
  • I refuse...
Re: 1975 cb550f
« Reply #107 on: December 06, 2024, 10:14:05 AM »
what prevents the tabs from spinning around the bolt? and what did you tap the bolt into?
Offline Fezzler
Re: 1975 cb550f
« Reply #108 on: December 06, 2024, 06:57:21 PM »
Keen eye.
The previous owner had started to build a bobber.  So fortuitous to me, he welded and tapped two substantial mounting points to bolt on a bobber solo seat, which I have since sold.
I simply repurposed the mounting points and used them for the Tuffside seat.  Tuffside seats have studs attached to the bottom of the seat pan and will be secured to the tabs with the provided washers, lock washers and wingnuts.
I don't think the tabs can spin since they are mounted securely at both the frame and the seat pan. The Tuffside seat pan was also molded specifically for the cb500/550 frame so it sits incredibly snug on and over the sides of the frame.
I originally was going to use the rear mounting studs for the Tuffside seat and had them positioned for the first crossbar you see below.  But since I want to mount a rear fender, that made access a little more tight than I cared for.  Easy access in the current position and just as secure.
Here is a picture of one of the mounting points from below the frame and both points on top of the frame.
« Last Edit: December 06, 2024, 07:51:01 PM by Fezzler »
Offline calj737
  • I refuse...
Re: 1975 cb550f
« Reply #109 on: December 06, 2024, 08:09:21 PM »
If the mounting bungs are tapped and the seat has studs, you’re not going to be able to thread the studs through the bungs to secure them with a wing nut. You’d need to “thread” the studs through into the bungs. See the problem?
You can drill the bungs out and then pass the stud through, washer and nut threaded onto the stud per your original plan. But the threads in the bungs gotta go…
Offline Fezzler
Re: 1975 cb550f
« Reply #110 on: December 06, 2024, 09:22:48 PM »
My bad.  I probably didn't articulate my response well enough or the picture wasn't worth a thousand words.
I've already attached the seat and it is snug and secure.  Probably unclear from the previous photo, there are mounting holes for the seat pan studs in the tabs.
« Last Edit: December 06, 2024, 09:26:13 PM by Fezzler »
Offline calj737
  • I refuse...
Re: 1975 cb550f
« Reply #111 on: December 07, 2024, 04:29:56 AM »
The picture makes it look as though they are threaded. That was my point. If they’re not, then “nevermind”.
Offline Fezzler
Re: 1975 cb550f
« Reply #112 on: December 07, 2024, 08:10:24 AM »
No worries.  Sage counsel from the elders always welcomed.
To those following along.  The thread has confirmed there are no threads.  We're all living in a simulation.
Re: 1975 cb550f
« Reply #113 on: December 07, 2024, 09:42:23 AM »
Ah. That would explain a lot.
Re: 1975 cb550f
« Reply #114 on: December 09, 2024, 07:10:44 AM »
Offline Fezzler
Re: 1975 cb550f
« Reply #115 on: December 09, 2024, 05:32:34 PM »
Chain...
...looks a little loose!
LOL.  Don't push me man!  I still need to pull the wheel back and adjust the chain.  I can't eat two pieces of elephant in one sitting.
Offline Fezzler
Re: 1975 cb550f
« Reply #116 on: December 12, 2024, 06:20:47 PM »
Stuff.
« Last Edit: December 12, 2024, 06:22:26 PM by Fezzler »
Offline Fezzler
Re: 1975 cb550f
« Reply #117 on: December 17, 2024, 10:07:32 PM »
More "braking" news.
Insight.  I have followed SohRon's Assembly Manual with great success and joy.  But he installs the rear brake pivot shaft after the center stand, swingarm, rear brake stop bar, chain, chain guard, etc. have been installed.
This is fine for the cb500/cb550Ks.  Well, with the "F" model of the cb550 the pivot shaft is much different than the 500/550Ks.  I could not figure out how to install it.  It would not clear the swingarm. So I dropped the swingarm to get it done.  Three steps forward, two back.  Pivot.  Moving on.
It has not been impossible or totally miserable, but I'm not sure I would buy someone's abandoned project bike again.  That said, enjoying the problem solving.
Re: 1975 cb550f
« Reply #118 on: December 18, 2024, 06:42:32 AM »
Yeah, that brake pivot shaft has to go in first with cb750's also...
Re: 1975 cb550f
« Reply #119 on: December 18, 2024, 07:02:00 AM »
Hey Fezz...A few years back, I bought a "basket case" '74 Kawasaki H2  [750cc, three cylinder, two stroke]. The project came in 4 large containers, a bare frame and two wheels.
It was a very frustrating project, but I found I learned so much about it during the process, and once finished I felt very satisfied and proud of what I had accomplished. I hope the same for you.
Offline Fezzler
Re: 1975 cb550f
« Reply #120 on: December 18, 2024, 09:52:57 AM »
Totally. I do like working on them.  After this one I need to decide if I'll do another, take a break, or exit the hobby.  As I sit now, I think I'll do another but starting to think about how to reduce space used by the stash of parts that keeps growing.  Also, kinda wonder if it would be fun to attempt another bike. Something small.  350?  125?  175? 450?  Yamaha?  CX500? Not really interested in the 750s, but does 500/550 knowledge "transfer" to the 750s?
Well, need to stay focus on digesting what I bit off here.
« Last Edit: December 18, 2024, 09:55:16 AM by Fezzler »
Re: 1975 cb550f
« Reply #121 on: December 18, 2024, 11:39:53 AM »
Yes, the CB750 is the same basic bike.
I would encourage it for a couple reasons such as parts are readily available, it's a historically significant bike and we can help you!
Re: 1975 cb550f
« Reply #122 on: December 18, 2024, 08:59:52 PM »
to me, cb750s are just easier to work on because everything is very similar to a 500/550 except just proportionately bigger...and maybe just a little bit simpler.  Honda's engineering always some to increase in complexity over time.
Re: 1975 cb550f
« Reply #123 on: December 19, 2024, 06:08:15 AM »
It’s taken a while, but I did it in the right order on my last two! I like to drill and tap the pivot tube for a grease fitting. Surprised Honda never provided an easy way to lubricate that spot…..
The availability of parts makes the 1969-76 cb750 a good choice. A word of caution: start with a very complete bike, preferably with a running engine. It’s very easy for the “sum of the parts” to well exceed the value of the completed project!
« Last Edit: December 19, 2024, 06:18:58 AM by BenelliSEI »
Re: 1975 cb550f
« Reply #124 on: December 19, 2024, 07:02:29 AM »
I think most of us have made that mistake once!
