Author Topic: Quick Petcock Question  (Read 1192 times)
Offline MrFry
    • T-Fry.com <--Under Construction
« on: February 23, 2007, 10:11:29 am »
what port is what?
i'm assuming one is for vacuum and the other is for fuel.
i have a 77 cb750, and am putting this older tank on it.
750rus
Re: Quick Petcock Question
« Reply #1 on: February 23, 2007, 10:14:26 am »
they should both be for fuel. on my 74 cb750 there are two fuel lines feeding the carbs.
Offline MrFry
« Reply #2 on: February 23, 2007, 10:18:19 am »
well.. that changes things...
guess i could just block one port off - seeing as i only have one line feeding my carbs>?
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: February 23, 2007, 10:20:09 am »
Why do you have only 1 line feeding your carbs?
No.
Offline MrFry
« Reply #4 on: February 23, 2007, 10:26:14 am »
i believe i do, i have one line coming off the original tank's petcock (didn't check if it splits to 2 though)
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #5 on: February 23, 2007, 10:30:07 am »
All of em I've seen are two lines to two nipples inb the carb rack...
No.
Offline MrFry
« Reply #6 on: February 23, 2007, 10:45:06 am »
that is my stock tank
you can see the single line coming off the petcock
i'm trying to see if i have a picture of the carbs to check to see if the line splits off
« Reply #7 on: February 23, 2007, 10:47:39 am »
The 77-78 carbs have different features over the earlier carbs.  One of these is a log feed from one fuel inlet nipple.
Offline MrFry
« Reply #8 on: February 23, 2007, 10:49:17 am »
that's what i thought
so... back to the original question - can i just block one off?
Offline MrFry
« Reply #9 on: February 23, 2007, 10:54:43 am »
or perhaps just have 2 lines go into 1 via "Y" splitter?
« Reply #10 on: February 23, 2007, 10:56:29 am »
Yes, you can block one off.  The petcock has it's own log.
Be carefull of the bung size.  Some petcocks only fit on smaller or larger bungs.  I thought the earlier two outlet petcocks fit on smaller bungs.  I don't have them all on hand to verify that, though.  I dunno, maybe it was a 78 thing.  Just check that before you buy.
