Author Topic: GL 1000 front wheel fitment  (Read 832 times)
Offline Ryan66
« on: March 27, 2021, 03:42:42 PM »
Does the dual disc gl 1000 mount up to the 550 front end? Seems like a an easy option for the dual disc setup.
1976 CB550k (cafe project)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: GL 1000 front wheel fitment
« Reply #1 on: March 27, 2021, 05:19:09 PM »
I’ve used them on cb750’s, if that helps you
« Reply #2 on: March 27, 2021, 06:51:39 PM »
Same wheel , different rotors , wider offset.. . Wheel is same , but rotors likely wont fit between any 750 of smaller triple trees.
 The whole front  end swap  is worth doing..
Offline Ryan66
« Reply #3 on: March 27, 2021, 09:04:16 PM »
Well that's good info I guess then. Thought it'd be a close swap
« Reply #4 on: March 27, 2021, 11:47:55 PM »
Yes to needing everything, i have everything except wheel from a GL 1000 executive but been stood for 20+yrs so needs refurb
