Author Topic: 1972 cb500 rear brake drum interchangability with mid 70's cb750 rear drum  (Read 661 times)
Offline bustech51
Received a email (at "The S.O.H.C. Drawer@gmail.com" ) from a guy who is looking to either replace his 1972  cb500 rear drum or machine it.  He heard at a locate "previously enjoyed"  bike yard that I deal in cb750 parts here at home.  Are the drums interchangeable with cb750 drum's or does anyone have a good '72 rear drum.
Let  me know at The S.O.H.C. Drawer@gmail.com
Trying to help out a fellow CBer
Al
Sent from my SM-T350 using Tapatalk
Offline 69cb750
CB750 drum, spokes differ, you need cb500 or cb550
Offline Bodi
They both have 40 spokes but it's very likely there are serious differences in the hub diameter/width, rim size, brake plate, axle diameter/length, and sprocket setup plus alignment to the engine (the 500 doesn't have the 750's extra sprocket carrier bearing as far as I know).
So possibly - with way more work than it's worth - a 750 hub could be made to fit?
You should be able to find a 500 hub or complete wheel on ebay?
Offline bustech51
That's what I was thinking.  All the various parts have differences.  Just trying to get proper info before I engage my  mouth then engaging my mind (mouth open vs mind in neutral.)  Thanks for the help.  Anyone have a good previously enjoyed hub in the London ON area?
The 500 is know to crack, you have the choice of fitting a 550 wheel but i know the K3 is different and not sure about the F if, however, you have the complete wheel with brake plate spacers and spindle the whole assembly should fit ok
