Author Topic: 78 750 K8 Keihin PD Carb accelerator jet plug removal  (Read 1677 times)
Offline martin_uk
  • CB750F1 CB750K8
« on: March 30, 2021, 09:22:52 AM »
I am having a problem cleaning passages without removing the plugs fitted to drilling for accelerator pump jets
I have read about removing the small plugs with pliers, but on mine they are flush with surface so nothing to grip.
I have considered drilling out, but then would need to get some made up, unless they are available?.
I have also considered drilling out then tapping hole so that a screw with seal could be fitted, apart from the entry one on carb with pump.
Has anyone found an easy solution?
Thanks
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
