Author Topic: Whats your favorite metal filler (minor pitting)  (Read 774 times)
Offline CBJoe
« on: March 31, 2021, 06:52:02 PM »
As opposed to bondo or JB weld....what is your favorite filler for non structural rust pitting in frame?   Especially in high use areas such as the center stand?  Not powder coating....just enamel or epoxy painting.
« Last Edit: March 31, 2021, 06:53:47 PM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline jgger
Re: Whats your favorite metal filler (minor pitting)
« Reply #1 on: March 31, 2021, 07:42:26 PM »
Brazing rod works pretty good. Thats if you have the torch for it.
Online Don R
« Reply #3 on: April 01, 2021, 02:58:27 AM »
Sand it out with 40 grit.  You will have to sand the filler anyway.
Offline CBJoe
« Reply #4 on: April 05, 2021, 02:24:19 PM »
Thanks for responses all....i'll take a look at how deep the pitting is and go from there.
'65 CB77
'66 CM91 (C90'ish)
« Reply #5 on: April 05, 2021, 08:03:45 PM »
Spray putty Joe. Hit it with etch primer first, then spray on a few coats of spray putty, sand it smooth, prime and paint. Sometimes a couple of full wet coats of enamel will be enough to fill those pits, but spray putty will definitely do the job. ;D
Offline jgger
« Reply #6 on: April 05, 2021, 10:09:51 PM »
Joe I thought you were talking about the "feet" on the center stand.  I don't think any kind of putty type filler would last long there. If itis wise where then you got several good suggestions. Now all you have to do now is pick one! Hahaha 😂
