Have managed to set the timing now, but I had to turn the baseplate counterclockwise to the limit to see the firing mark. I guess the firing mark should appear somewhat in the center of the slot. I could have missed one notch on the cam when I assembled the cam/chain. Or, there is excessive slack in the chain. There was a bit of play when wiggled on the cam. I suppose that when you turn the crank, there should be direct response oh the cam? (excuse my bad english, it's not my native language)
