Pulled the pan off my "good" motor a while ago, found the expected sludge, but the screen was clean, and no metallic bits in the sludge.
Did the same to my 2nd motor, had the expected sludge, but the screen was blocked with crap, including metallic aluminium debris. Lifted the breather and found this, presumably the source of the metal. I know I will need to strip the engine now, but is this valve cover still useable? Will oil spray up and out the breather? Thought about repairing with JB Weld, but am concerned that if it came loose and went through the engine, not much good would occur. What about using fibreglass mat and resin?
Thoughts welcome,
Thanks,
Kevin
