Author Topic: Cracking Rear Mount  (Read 863 times)
Offline BrickWoll
Cracking Rear Mount
« on: April 11, 2021, 10:01:19 PM »
Hello all,
I have spent the winter rebuilding the top end of my '77 CB550.  This weekend I was looking at areas that might need cleaning before I put the cylinders and head back in the frame and noticed what looks like a small crack at the rear of the case.  It's where the case mounts to the frame.  Is this a known point of failure on the 550s?  Possibly over-tightened bolt by the PO?
Thanks for checking it out.
'77 CB550 K3
Offline caluser2000
Re: Cracking Rear Mount
« Reply #1 on: April 11, 2021, 11:12:45 PM »
My '76 cb550f has done 164,000 plus kms without cracking there.
Bike may have been crashed in its past life possibly..
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
« Reply #2 on: April 12, 2021, 01:15:14 AM »
Are you sure its a crack and not a casting/paint flaw is the first question.
I have never seen one crack there in use, could have been dropped but those casings are very robust.
« Reply #3 on: April 12, 2021, 01:45:16 AM »
im with bryanj,a few have posted over the years with these cracks here n there that aint cracks.
Online BenelliSEI
  • 1969 cb750
« Reply #4 on: April 12, 2021, 06:27:53 AM »
+1. Move ahead.
« Reply #5 on: April 12, 2021, 09:40:21 AM »
Likely cracks in the casting die. It it is   itl will be raised..
Offline BrickWoll
« Reply #6 on: April 12, 2021, 09:44:28 AM »
bryanj - I'm not sure at all.  It could be paint, but it's raised to the touch, which would be odd if it was just a thin paint coat cracking.  Maybe I'll take it down a bit with a brass brush to confirm.  Thanks.
'77 CB550 K3
Offline BrickWoll
« Reply #7 on: April 12, 2021, 09:46:55 AM »
754 - This seems correct as there is definitely texture to the cracks.  Thanks.
'77 CB550 K3
Offline BrickWoll
« Reply #8 on: April 12, 2021, 09:49:00 AM »
Thanks for the feedback everyone.  I'm going to press on with the install.  Riding weather is rapidly approaching here in the PNW.
'77 CB550 K3
