I had thoughts about 18" front rim on my K6 and how to get the right caliper on-off when I take my wheel on-off.
The right caliper must go off to remove the wheel.
The upper caliper bracket m6 bolt sit very tight to rim and should be a problem with 18" rim on my bike. The bolt need to be taken out completely and need space.
My rim is an 19" alu wheel, 2.15" wide. Rather slim outside for its size.
F2 fork with its std dual brakes will be an easier alternative?
