Author Topic: To replace or not replace - Sprockets  (Read 1832 times)
Offline JWB
« on: May 04, 2021, 05:32:04 PM »
To a novice like me these sprockets look ok, but not sure.  So from the picture, can you tell if they need to be replaced or not?
« Last Edit: May 05, 2021, 05:13:27 AM by JWB »
Re: To replace or not replace - Sprokets
« Reply #1 on: May 04, 2021, 06:06:23 PM »
Yes, if you look at the semicircle at base of teeth it is "deformed" to one side
« Reply #2 on: May 04, 2021, 06:22:26 PM »
agreed...those are shot
Offline Bodi
« Reply #3 on: May 04, 2021, 06:36:13 PM »
I have seen worse rear sprockets but not often. The front one, it's not so easy to say but just get a new one. And a chain of course. Best to always replace the chain and both sprockets.
bad sprockets will ruin a new chain quickly. A worn chain will damage new sprockets quickly.
Offline Alan F.
« Reply #4 on: May 04, 2021, 07:41:26 PM »
I'd be tempted to keep that front sprocket, cheap bastard that I am. I guess I'd better buy some new ones and leave it at that.
« Reply #5 on: May 05, 2021, 12:50:15 AM »
A worn sprocket will shorten the life of a new chain. Sprockets are cheap compared to a good chain.
Offline Old Moe Toe
« Reply #6 on: May 05, 2021, 01:28:46 AM »
Depends on how "sphincterly challenged" or tightassed you are. I know a guy who on a "round Australia" trip back in the day only changed his sprockets when they were so worn they would no longer turn the chain.
Offline pjlogue
« Reply #7 on: May 05, 2021, 02:45:02 AM »
Don't think I have seen a rear sprocket that badly worn before.  Yes, replace the sprockets.  If the sprockets (rear at least) are that worn, I would replace the chain as well.
-P.
Offline JWB
« Reply #8 on: May 05, 2021, 04:43:16 AM »
Much obliged for the input.  New sprockets have been ordered.
Re: To replace or not replace - Sprockets
« Reply #9 on: May 07, 2021, 06:21:16 PM »
...... and a chain.
