Author Topic: 2015 Yamaha FZ-09 Challenge 9 Track Bike Project  (Read 6408 times)
« on: May 07, 2021, 11:40:55 PM »
New project -- convert a naked-style 2015 Yamaha FZ-09 (850cc inline triple) into a Challenge 9 style track bike.
What's a Challenge 9?  It was a French road racing series based on the Yamaha FZ/MT-09 with modified bodywork.
What did the bikes look like?
mt11 by Donald Leonhardt, on Flickr
_DSC6117 2 by Donald Leonhardt, on Flickr
So here's the donor - a salvaged title 2015 Yamaha FZ-09 (resulting from a low-speed collision bending the front forks)
Untitled by Donald Leonhardt, on Flickr
After sourcing a pair of new forks, a used radiator, and a set of GB Racing engine cover guards for the clutch, alternator and water pump covers.
IMG_0510 by Donald Leonhardt, on Flickr
« Last Edit: June 02, 2021, 08:48:24 PM by SOHC4 Cafe Racer Fan »
Re: 2015 Yamaha FZ-09 Challenge 9 Track Bike Project
« Reply #1 on: May 08, 2021, 06:22:16 AM »
 I've always wanted to take one of those for a spin and try it out. From the reviews and tests they seem to be a very capable and fun sounding hooligan bike.
« Reply #2 on: May 09, 2021, 04:28:01 PM »
The engine is the star of the show.  Lots of punch in a lightweight package.  It needs a little more weight on the front - hence the swap to rearsets and clipons - and this will help for a more appropriate track body position, too.
The stock suspension was also lacking, so that will be upgraded.
Offline emlupi
« Reply #3 on: May 11, 2021, 09:15:08 AM »
They are great bikes, a real blast to ride. The triple engine has lots of character with good torque all across the range. Once it gets above 6000 rpm it’s a Jekyll/ Hyde personality. It wants to wheelie even if you don’t, especially in 1st or 2nd gear. Very light weight and agile, a great bike for the street.
Unfortunately, for me anyway, the seat was just too uncomfortable to bear for more than about an hour or so. Even an aftermarket replacement didn’t really help much so I traded it in. That shouldn’t make much difference for a track bike. Challenge 9 sounds like it ought to be a lot of fun. The FZ/MT-09 won’t let you down.
« Reply #4 on: May 22, 2021, 09:14:09 PM »
Update:
To the donor, I installed the parts for the factory slipper/assist clutch for the 2015 XSR900.  This including disassembling the stock FZ-09 clutch, replacing the basket, changing several steel and friction plates in the clutch pack, and adding a new pressure plate.
Next, I discovered that the used stock radiator had a pin-hole leak, so I replaced it with an aftermarket radiator and guard.
My paint and body friend Andrew "Paint by Bondo" Babish fitted the brackets for the front cowl, radiator guards and tail unit.
We then removed the body work for a base coat of matte grey metallic paint, to add graphics later.
« Last Edit: June 02, 2021, 08:52:06 PM by SOHC4 Cafe Racer Fan »
ken65
« Reply #5 on: May 22, 2021, 10:12:35 PM »
Good job.
« Reply #6 on: May 27, 2021, 11:17:29 PM »
I removed the stock handlebar mounts and top triple clamp, and then installed new mounts allowing for more clearance for a GP5 steering damper, installed the damper and Woodcraft clip ons to allow for a 3" lower than stock handlebar position.  This combined with Woodcraft rearsets will provide a more aggressive track riding position and place more weight on the front tire.
Also in the process of installing a Brembo 19RCS radial master cylinder.  I will be swapping out the stock 298mm rotors for 320mm Galfer wave rotors and 10mm caliper spacers to adjust for the larger diameter rotors.
« Last Edit: June 02, 2021, 08:52:22 PM by SOHC4 Cafe Racer Fan »
schwartzstuart6
« Reply #7 on: May 28, 2021, 10:03:25 AM »
It's the engine for me
Sent from my SM-A107F using Tapatalk
« Reply #8 on: May 28, 2021, 11:42:14 AM »
Oh, I get what you're saying.  The engine is the high point of this bike.  The stock suspension is not so great, and will be upgraded.  I may decrease the rake a little (especially since I have a damper installed).
« Last Edit: May 28, 2021, 04:46:09 PM by SOHC4 Cafe Racer Fan »
« Reply #9 on: May 28, 2021, 04:48:56 PM »
Woodcraft rear sets assembled.  Unfortunately, the engineers at Yamaha decided that rear set changes would require removal of the swingarm pivot bolt, so I'll have to use a jack and relieve the weight on the swingarm pivot to remove and replace the rear sets.
« Reply #10 on: June 03, 2021, 08:23:05 PM »
Major upgrade.
Ohlins S46 shock, Ohlins NIX30 cartridge kits for the forks, Graves Motorsports full titanium exhaust, and Woodcraft rear sets:
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #11 on: June 04, 2021, 08:51:07 AM »
Will it be street legal when done or will you race it?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #12 on: June 04, 2021, 08:54:30 AM »
Neither. It will be a track day bike.
« Reply #13 on: June 04, 2021, 09:20:15 AM »
Don - The one change you might consider making is to lower the headstock. That is possibly the greatest change to the 2021 from prior model years. New model has the headstock lowered by 30mm. Reports are that it drastically improves front end handling.
Hi Cal,
Funny you should mention that. Yes, I've heard about this significant chassis change to the new bike.  Short of customizing a cast aluminum frame, I can mount the triple trees lower in the fork tubes, pushing the tubes through and lowering the front end. This is also one of the reasons I added a steering damper as the bike needs more weight on the front end -- it can feel light on the front especially above 115 mph.
« Reply #14 on: June 04, 2021, 09:46:06 AM »
...I can mount the triple trees lower in the fork tubes, pushing the tubes through and lowering the front end. This is also one of the reasons I added a steering damper as the bike needs more weight on the front end -- it can feel light on the front especially above 115 mph.
Yeah, with all the changes you're making to steering gear, and of course the challenges of altering the frame, seems like you're headed in the right direction. Didn't notice your choice of rubber?
Thanks, Cal.  I'm going with Dunlop Q4 tires.  I've used them on track on an MV Brutale and Ducati 748, and was impressed with the grip level especially with no tire warmers.
« Reply #15 on: June 13, 2021, 10:57:51 PM »
More progress.  I lowered the front forks by 30mm to increase weight on the front and sharpen handling.  I also drilled locator holes into the clip ons for the stock throttle and start/stop/throttle map controller, and installed bar ends and a brake lever protector.  I also installed some Renthal grips.
I had to hold off on the rotor upgrade because I still need to mill off 1mm off the caliper spacers (to fit the calipers up to the larger diameter rotors).
Offline river
« Reply #16 on: June 15, 2021, 07:27:54 AM »
Excited to see this come together but, I must admit, I'm a little sad to see the streetable FZ you had go bye bye. That bike was really sharp. This should be rad too though.
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
« Reply #17 on: June 15, 2021, 07:50:09 AM »
Thanks, Chris.
Even with a project like this, there are always hiccups when you deviate from "stock" as you can attest from building you new rear end for the Squirrel.  It's nice when it all just drops in, but also satisfying when you figure out the solutions (as long as that process doesn't cause too much brain damage).
« Reply #18 on: June 15, 2021, 06:35:38 PM »
The bike is off to the tuner.  I'm swapping in a Flashtune ECU.
The flashed ECU does the following:
Installs a exhaust specific map, tunable with a Dyno
Fuel injector proportioning
Ignition timing
Immobilizer function
Cooling fan temps (lowers threshold)
Rev-limiter control (removes soft limiter)
Removes top speed limiter
ECU based quick-shifting with additional quick-shifting hardware (e.g., Translogic quick-shifter)
Speedometer calibrations
The ECU is already tuned to my Graves Motorsport full titanium race exhaust.  It will make approximately 131 hp with the tune.
I am also installing a Translogic quick-shifter for clutchless up shifts and auto blipping downshifts.  This helps quicken acceleration and on deceleration decreases chassis upset from downshifting.  I've used this exact same set up for aggressive canyon riding and it is makes the bike so much easier to ride harder.
« Reply #19 on: June 23, 2021, 07:15:18 PM »
Got the bike back from the tuner.  It's making noticeably more power -- even punchier -- and the quickshifter is functioning well.  The autoblipper downshifted is seamless.
Oh, and I added a Graves front sprocket cover.
« Last Edit: June 23, 2021, 07:17:58 PM by SOHC4 Cafe Racer Fan »
Offline Nicklopic
  • New York
« Reply #20 on: June 24, 2021, 05:16:54 AM »
I like where this is headed and seems like it will be a blast!
Following lol
80' CB650
Build Thread
« Reply #21 on: June 29, 2021, 08:58:27 AM »
The electronics are sorted and most of the mechanical elements of the track bike are done.  The bike is back in the hands of my painter to paint the base color of the bodywork (dark charcoal metallic) and lay out graphics (some red and light gray/white).
« Reply #22 on: July 17, 2021, 09:24:11 PM »
I visited my painter today.  All of the bodywork was completed and the base coats of grey metallic were applied.  I laid out the graphics and Yamaha stencils for painting an accent gray and black pin lines.  The paint should be done in about 10 days.  Pics to come.
« Reply #23 on: July 18, 2021, 06:57:47 AM »
Well, I’ve had my share of track bikes with bare unpainted fiberglass bodywork.  This time I was simply going to do a single 2-stage (base-clear) color and decals but my painter wanted to make it look that much cooler and we are doing a trade on the paint job. So I’ll do my best to keep it pretty.
I totally “get” what you’re saying. That’s why this bike has a salvage title.
« Reply #24 on: August 14, 2021, 11:15:20 PM »
Got the painted bodywork back today.  It's the stock grey metallic, but clear gloss coated instead of a matte clear, with nardo grey and black line work graphics.
The belly pan is also painted but needs to have the heat insulation material adhered to the pan.
I also replaced the stock Brembo axial front master cylinder with a Brembo 19RCS radial master cylinder.
Next up: additional brake upgrades.
