Author Topic: Does a 550 cam cover fit on a 500?  (Read 659 times)
Offline Harold_Boom
« on: June 06, 2021, 01:57:13 AM »
Hi all,
I realised tonight that one of my tappet covers was being hit by the tappet arm. After some googling I believe the it's the same issue a lot of people have encountered on here with the rocker shafts being worn.
The fix is to get a later model cover like a 77 but does the 550 cover fit onto a 72 500?
Thanks
Re: Does a 550 cam cover fit on a 500?
« Reply #1 on: June 06, 2021, 02:49:48 AM »
Yes all 500/550 cam covers fit all heads
Offline Harold_Boom
« Reply #2 on: June 06, 2021, 02:58:38 AM »
Great thanks mate!
Offline flatlander
« Reply #3 on: June 06, 2021, 04:15:37 AM »
of you find an earlier type cover that's in good shape, you can also prevent the rocker shafts from rotating and wearing out their bores by putting an o-ring between the end of each shaft and the end cap stud. same size ring as on the studs themselves will fit.
« Reply #4 on: June 06, 2021, 10:11:07 PM »
the cover wears.
