Author Topic: Prototype tach delete plug  (Read 497 times)
Offline kerryb
  • Not a very
« on: May 14, 2021, 07:53:31 AM »
I wouldn't want to delete my tach...but I'm assembling and engine to test and run without the tach drive in place so I made this to cover the hole.  I say prototype because there wasn't much thought put into the design before cutting.  The idea for the clamp came after the grooves were cut so the sizing needs some correction.
I was feeling clever, what would you do to improve it?
No, I don't have plans to sell these, but if someone needs one to plug the hole while looking for the parts to fix it right, that could be arranged.
Online BenelliSEI
  • 1969 cb750
Re: Prototype tach delete plug
« Reply #1 on: May 14, 2021, 06:30:23 PM »
Looks good. Should work well.
Offline BrickWoll
« Reply #2 on: May 14, 2021, 08:50:27 PM »
+1. Currently have an open hole after the OEM cover turned to mush.  I would buy that in a second.  Looks great.
'77 CB550 K3
Offline kerryb
  • Not a very
« Reply #3 on: May 14, 2021, 10:03:02 PM »
Send me a message with your address,  I'll let you be the guinea pig for the design improvements.
