The cams were broken down into 5 distinct types:
The K0
The K1-K3.
The K4/5/6
The F0/1 and K7/8
The F2/3.
The K0-K6 types will all drop-in for each other, with slightly varying carb jetting: the K0 and #657A carbs use #110 mainjet while the others use #105.
The F0/1-K7/8 uses the leaner mainjets, usually #105. The F0 and F1 with the roundtop carbs use a leaner slide needle because the intake valve opens later in this cam. The later F1 and the K7/8 use the PD41 carbs with #110 mainjets and #38 (or #37.5) pilot jets.
The F2/3 uses the PD42a/b carbs (some K8 also got these carbs toward the end of production). These may have #110 or #105 mainjets, with #37.5 or #35 pilot jets. The PD42 carbs have only one needle slot. Spark timing comes on slower in this cam to prevent spitback up the intake tract from the longer overlap cycle.
There is also the "A" cam from the 750A but it is not a performer cam. It makes the 750 run like a 500 twin, but smooth!
All the cams will inter-fit the other engines, but you may have some tuning to do to make it run well. The later cams (F0 onward) idle better than the earlier ones, especially in hot-day city traffic.
