Author Topic: Did I F**k this up?  (Read 645 times)
Offline gbal06
Did I F**k this up?
« on: May 22, 2021, 07:13:14 AM »
I thought I would be smart and place my piston in the purple super clean over night.  I woke up the next morning with this white foam which wiped off easy but left the piston looking like this.  Is it reusable or do I need to get another?  Thanks
1978 CB550K
Offline jgt750
Re: Did I F**k this up?
« Reply #1 on: May 22, 2021, 07:52:33 AM »
I'd say wallhanger now. Seafoam, Gumout, Gas, Varsol, Mineral Spirits all work well.
« Reply #2 on: May 22, 2021, 08:16:05 AM »
Check with a micrometer..
 Someone likely has a used one laying about..
Offline gbal06
« Reply #3 on: May 22, 2021, 09:04:14 AM »
if it is still inspec then its usable even though it looks like the finish was removed on it Hondaman?
Offline American Locomotive
    • sohc4
« Reply #4 on: May 22, 2021, 09:26:08 AM »
Most household cleaners/degreasers are very alkaline and will readily attack aluminum. Even if that piston measures out good, I probably wouldn't put it back in an engine I cared about.
Offline gbal06
« Reply #5 on: May 22, 2021, 10:28:27 AM »
does anyone know of a place other then ebay(expensive)  and 4into1(out of stock) that I could get a new single std piston?
« Reply #6 on: May 22, 2021, 11:44:42 AM »
Sure the piston is shot?
Try piston rings on it. Any play up-down? If alu has been eaten, ring grooves might show that easier.
I think max play is 0.1mm feeler gauge to squeeze in over or under ring.
Cheap pistons are otherwise available at www.cruzinimage.net
Std size might be too small for  used bores since piston/bore clearance is 0.025mm.
+0.50 kit need new bore.
Offline gbal06
« Reply #7 on: May 22, 2021, 12:09:57 PM »
I will have to check when I get off of work. Is it a concern if the AU is gone off the sleeve? Also is there a place that sells just a singular piston or do they all come in a set?
« Reply #8 on: May 22, 2021, 12:20:43 PM »
Like i said ask on here fir a used one... it will match your 3 other Used ones..
