Thanks Per, I paid silly money for that "Patina", but I'm glad I did, as the seller had intended to have it repainted then sell it anyway, and as we both know, these old bikes are only original once. Well, this bike never actually existed as it's been "Fankensteined" from 5 or 6 bikes, but if I didn't tell anyone, who'd know? The engine number doesn't match the engine number on the ID plate on the frame, but I still have the remains of the original engine that I'll keep and throw in with the bike, if and when I sell it. Considering that it only weighs 320 pounds, the T350 with me on it only weighs as much as a CB750 with no one sitting on it, it might be my "Old man bike" when I'm too old and frail to hold up a CB750? We'll see.
Anyhoo, today started off crappily, but it finished OK. I needed to go shopping, which I hate anytime, and I wasn't holding out much hope for finding the sparkplugs I needed for the little green meanie. None of the first 2 shops I went to would allow me to open the spark plug packets (which were in locked cases, so I couldn't sneak a peek) and as a result, because they didn't have any plugs that are listed for T350's, I ended up with 6 spark plugs I can't use. Finally, at the last shop I went to, the spare parts guy was great, he found the same plugs that I needed, and was happy to open the box so we could check. $12 well spent.
I also bought a litre of low smoke semi-synthetic 2 stroke oil, so I made up 5 litres of 25:1 premix and dumped it in the tank, and turned the fuel petcock first to "on" then to "Reserve", but no fuel travelled down the clear lines to the carbs? WTF?
T350 Sunday 13 Jun 2021 4 by
Terry Prendergast, on Flickr
Anyway, no time to worry about that, I connected the new plugs, earthed them on the head and kicked the engine over, and could see a nice fat spark. Excellent! I screwed the plugs in, and fitted their caps.
The next job was fitting the oil tank. This probably would have been easier to do yesterday before I ran the wiring harness, but no biggie, I used some more of that rubber strap to make some rubber mounts for the oil tank, and managed to bolt it in place. OK, that was all the easy stuff, now it was time to "McGyver" an oil line from the tank to the pump. The original had long ago gone to God, but I had some of the remains, plus some broken lines that had been on the old engine, so I found one piece that I bolted to the pump, and another piece that I bolted to the oil tank.
T350 Sunday 13 Jun 2021 by
I grabbed my special tube cutting tool (gardening secateurs) and cut both pieces:
T350 Sunday 13 Jun 2021 1 by
Then slipped some "self hardening" fuel hose over both pieces. When I say, "Slipped", I'm joking, it was a tight fit on both sides, so should be a nice tight seal.
T350 Sunday 13 Jun 2021 2 by
Now I have no idea how the hose should have been originally routed, but I guess it'll make sense when I receive the hose that RB sends me. For the time being, I poked it thru the fuel pump inspection hole, and it will be fine there, and the good thing is I'll be able to see if the (red) 2 stroke oil is passing thru the pipes.
T350 Sunday 13 Jun 2021 3 by
I thought about why the fuel wasn't filling the float bowls, and I remembered adjusting the float levels when I had the carbs apart, and I reckon that, seeing I had no specs to work from, that's why no fuel was flowing. It was too late to pull the carbs and adjust the floats, but tomorrow is a public holiday, so I'll have plenty of time to pull the carbs, set the float levels, and give it a kick in the guts. More then.
T350 Sunday 13 Jun 2021 6 by
T350 Sunday 13 Jun 2021 7 by
