Author Topic: New valve ?  (Read 964 times)
Offline gbal06
New valve ?
« on: May 25, 2021, 02:04:45 PM »
My valves are on the end of the spec for being good. If I buy new ones is it a matter of just putting in the new ones and lapping them or do I need to take them to a machinist?
Offline kerryb
  • Not a very
Re: New valve ?
« Reply #1 on: May 25, 2021, 02:39:47 PM »
I'm no expert at this, but...if you think your valves are near done, shouldn't the guides be checked for wear?  If the guides are still good then how are the seats?,  will lapping provide an adequate seal, or should they be professionally recut?  Further inspection seems in order.  Do you know how many miles are on them?
Offline gbal06
Re: New valve ?
« Reply #2 on: May 25, 2021, 05:19:40 PM »
Guides and seats are good with less then 2500 on the speedo. I don’t know about PO
Offline Flyin900
Re: New valve ?
« Reply #3 on: May 25, 2021, 06:47:33 PM »
Something is off there if there is only 2500 miles on the engine, it is  very unlikely that the valves would be worn out of spec.
What spec are you referring to for this assessment? Possibly someone changed out the speedo or the motor/ head????
« Last Edit: May 25, 2021, 06:49:25 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline gbal06
Re: New valve ?
« Reply #4 on: May 25, 2021, 07:50:23 PM »
I agree. As I take this motor apart   I find thinks are not what they seem. There should be no way everything is at the low end of spec for such low miles. Here are the specs I am using.
Re: New valve ?
« Reply #5 on: May 25, 2021, 10:09:35 PM »
Wiggle valve sideways in guide at 10mm lift or more without springs. It should not be a "clonky" lash.
Exhaust is the common guide to find this wear.
Bent valve if not moving easy in its full working lenght in-out the guide.
I have seen shot valves, the outer edge of dish very thin, sealing surface concave. Jagged edge pieces have fallen off.
Seats to have a shiny ring where valve is sealing. Not too wide. I guess 1- 1.5mm is OK
Re: New valve ?
« Reply #6 on: May 25, 2021, 10:31:14 PM »
Easy to tell if they are worn. Will have  double the wiggle front to back vs sideways.
 Its apart.. measure  everything.. use a mic..
Re: New valve ?
« Reply #7 on: May 25, 2021, 11:14:25 PM »
Put up some pics of the valves and let us see
Offline gbal06
Re: New valve ?
« Reply #8 on: May 26, 2021, 07:07:40 AM »
I will check the movement and send pics when I get home today.  I mic'ed them and all of them are at the low end of service(which I think is weird). But if I did replace them, is it as simple as buying a new pair and lapping them or does it need to go out to a machinist?
Re: New valve ?
« Reply #9 on: May 26, 2021, 12:38:51 PM »
IF the seats are good just lap them in BUT if they are actualy within spec why bother
Re: New valve ?
« Reply #10 on: May 26, 2021, 02:58:00 PM »
The valve stems seldom wear in these engines: about 0.0004" is the worst I have seen (unless damaged by water).
MUCH more common is worn valve guides in the post-1971 engines, as Honda switched away from Stellite metal to common cast iron then (except in the 750F0 engines). The iron guides can get rust from sitting, especially if the oil was old, then parked for 10 years, with water vapor then trapped in the guides. It takes about 10 minutes of runtime then to make the guides' holes too big!
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: New valve ?
« Reply #11 on: May 26, 2021, 07:14:37 PM »
Check everything in the head, it’s a lot of work to backtrack.
I’m thinking if the valves are worn, so are the guides and seats.
Don’t go to just any machine shop for head work, they’ll butcher it, several here on the forum can help, Hondaman did my head and cylinders, runs perfectly.
Get Hondaman’s book.
Read “Thoughts of Hondaman” here on the forum, very helpful.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: New valve ?
« Reply #12 on: May 26, 2021, 07:16:06 PM »
http://forums.sohc4.net/index.php?topic=7401.0
Thoughts of Hondaman ( Mark Paris)
1973 CB 750 K3
Offline maxheadflow
Re: New valve ?
« Reply #13 on: May 26, 2021, 07:25:53 PM »
Did Honda really use stellite as a guide material?  Rockwell hardness would require carbide reamers and AFAIK they were always cut with high speed steel.  IIRC the valve faces and seat were stellite.
Re: New valve ?
« Reply #14 on: May 29, 2021, 05:19:38 PM »
In the early 750 and the old Hawk engines (CB/CL250/305) they used Stellite, and when disassembled young (like 50k miles or less) they looked like glass inside. They have a slight bluish cast to them, so they are easy to tell apart from the later cast-iron ones. The old Honda shop manuals show a "valve reamer" tool for use in these engines (in the front pages, Tools section), but it took a Serdi machine to ream new ones if installed: they had to be high-speed honed. The valve seats in these same engines were sometimes Stellite and sometimes steel, changing to iron in the (750) K4 engines. I was surprised the first time I found Stellite in the 750F0 engines, and the first-year 750"A" heads also sometimes have them. They are so hard that if the valve stem is bent (like too many RPM) the edges of the guides break off like glass at the port side.
Offline maxheadflow
Re: New valve ?
« Reply #15 on: May 30, 2021, 02:35:11 PM »
Thanks for the info..
