Author Topic: Brake Caliper  (Read 493 times)
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
Brake Caliper
« on: August 09, 2022, 10:23:29 PM »
Hi on the brake caliper on K5 750 has been dragging. I took it apart and it looks like the photos below. I replaced the piston a seal a year or two ago. Being that its all crusty around the pad do I need to replace the seal again or just clean everything all up?
Also What was the original color of the caliper form the factory gloss satin or matte black?
What's the best way to clean up the dragged up rotor Scotch Brite pad?
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Re: Brake Caliper
« Reply #1 on: August 09, 2022, 11:41:13 PM »
Depends upon what you really want, TruDisc can grind the rotor to make it flat and parallel again if it isn't going to go below minimum thickness doing so...
He won't thin rotors below min specs.
Godffrey will thin them...
Dental tool to remove and deposit in the groove for the seal and ScotchBrite to clean bore and internal.
Want the groove seal spotless for the seal to work correctly.
Offline newday777
Re: Brake Caliper
« Reply #2 on: August 10, 2022, 02:47:08 AM »
That's very crusty. If you replaced the piston and seal in the past 2 years, I would look deeply as to why it's leaking already. It shouldn't be leaking like that in 5-10 years or more under normal riding conditions.
Did you put in a new piston and seal when you replaced them? Who did you get them from?
Did you clean out the groove and bore?
How has it been riden? Lots of dirt roads?
Definitely at a minimum clean up the rotor with scotch Brite and brake cleaner, better to have it resurfaced.
https://truedisk.net/
Stu
My current rides
Prior bikes....
Offline newday777
Re: Brake Caliper
« Reply #3 on: August 10, 2022, 03:24:41 AM »
For the painting use a satin 2K paint
SprayMax 2K Hot Rod Satin Black Spray Paint | Automotive Topcoat With Long Lasting and Durable Finish, High Chemical and Weather Resistance | 2 Pack https://a.co/d/44dncTE
Stu
My current rides
Prior bikes....
