Author Topic: YE OLDE OIL PUMP [NOT OIL BRANDS] QUESTION  (Read 547 times)
Offline itsahonda4
    • www.wfomodels.com
« on: June 06, 2021, 07:38:07 PM »
hey all, Finally getting the mongrel-damaged-cases-K0 back together and the oil pump has had a very hard life with damage to the rotors on both the supply and return sides. While its not bad, I had a spare pump laying around, so I stripped it and installed all new springs, cutoff valve etc and I noticed that the end float in the drive shaft is about 1/4" and there doesnt appear to be any way to adjust/eliminate that end float......
Is this normal or am I missing something????
Al
Re: YE OLDE OIL PUMP [NOT OIL BRANDS] QUESTION
« Reply #1 on: June 06, 2021, 11:31:11 PM »
There is always somefloat
Offline flybackwards
« Reply #2 on: June 07, 2021, 10:14:13 AM »
Mine was the same way when I took it off - same comment about end play -  cleaned it out and re-installed seems to stay centred just fine.
Offline slikwilli420
  • Master of Disaster
« Reply #3 on: June 07, 2021, 01:40:30 PM »
Al
End play on the shaft should be in the few thousandths range, not 1/4". You must be missing one of the pins that holds the inner rotor.
