Author Topic: Ive gotta stop this - the stress is gonna kill me  (Read 909 times)
Offline itsahonda4
    • www.wfomodels.com
« on: June 18, 2021, 04:14:48 PM »
Well I got the much maligned ex-chopper #$%*box wrecked K0 back together. Took my time [days in fact] and assembled the engine, put it in the frame, cleaned the carbs in my son's ultrasonic machine, statically timed the ignition, rechecked the valve gap and  assembled everything in accordance with known good practice......
And bugger me it wont run.
Latest iteration is that it will start on the choke hot or cold, but the instant the choke is turned off it stops dead!
Ive pulled the carbs again, blasted all the orifices with cleaner and air, rechecked the needle settings [middle position], confirmed all the pilots are clear and the same size, and a bit fat nothin'.
Oh and new plugs, new condensers, advancer is working fine, coils and points plate is off a running K1 I have [I swapped them to confirm it wasnt an ignition problem].....dar dum dar dum.....
Help please.
Al
Offline itsahonda4
    • www.wfomodels.com
Re: Ive gotta stop this - the stress is gonna kill me
« Reply #1 on: June 18, 2021, 04:15:45 PM »
BEFORE....
« Reply #2 on: June 18, 2021, 04:51:31 PM »
Air/fuel. Compression. Spark properly timed.  It runs.
Look at the spark plugs. Dry or wet?
Are you operating the choke correctly,  and not reversed on/off?
If it only runs with choke on, then the pilot circuit in carbs is suspect.
Offline itsahonda4
    • www.wfomodels.com
« Reply #3 on: June 18, 2021, 09:16:57 PM »
up for on......
spark plugs are wet, thats what I dont understand which suggests its running very rich.
But i dont understand why it stops when the choke is turned off [lever down].
Ill go back in again and check the idle circuits tomorrow.
Al
« Reply #4 on: June 18, 2021, 09:45:00 PM »
have you tried holding the rpm higher?does the idle screw need winding up?
« Reply #5 on: June 18, 2021, 11:20:20 PM »
Is the idle screw holding the slides too open and flooding the plugs? Had that after incorrect bench sync. OR look and see if the slides are still open with tickover screw backed all the way out that will do it, again incorrect bench sync
« Last Edit: June 18, 2021, 11:22:24 PM by bryanj »
Offline lash
« Reply #6 on: June 19, 2021, 03:21:13 AM »
Are the carb slides in backwards?
Offline disco
« Reply #7 on: June 19, 2021, 04:52:54 AM »
“Latest iteration is that it will start on the choke hot or cold, but the instant the choke is turned off it stops dead!”
That says to me that it’s not getting enough fuel. Sounds like you have spark and compression. Try spraying some ‘Aerostart’ into the carbs. If it fires up for a few seconds, I would be pulling those carbs and putting them under the microscope. Sounds like something is not right with ‘em.
« Last Edit: June 19, 2021, 04:54:30 AM by disco »
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline itsahonda4
    • www.wfomodels.com
« Reply #8 on: June 20, 2021, 05:16:01 PM »
and indeed the plot thickens....
I raised the idle . These are the separate 4 cable carbs so its not as simple as the later gantry type carbs, but I did it and the bike immediately sounded and acted more normal.
BUT it still dies after 30 seconds or so. So I checked fuel flow from the tank and its all normal and I did remove the inline filters I had in place. Still dies.
Im going in tomorrow to check the float level and see if thats the problem.....
Al
« Reply #9 on: June 20, 2021, 09:01:38 PM »
What he said...
(I've done this on a SuperHawk, long [long, long] ago...).
Online Don R
« Reply #10 on: June 24, 2021, 08:43:43 PM »
 I did the bass akwards slides once myself, when they were correct, the numbers someone (ME?) wrote on the tops were backwards too.
