I figured I would write a post showing how I put a 160 tire on my 78 cb750f. I of course did this with help of the forum. I could not find an exact procedure outlined so here is my attempt. Here is a list of everything I used and it all bolted right up. I have done a monoshock conversion to my bike so there is some extra tubing. I can not see any reason this would not work had I left the original shocks on the bike...?
I am having trouble trying to put photos inside of the post rather than at the end. If the photos don't post I hope the links work...
I think part of the reason this worked out is the 78 has an offset on the transmission output shaft. there is a step of about 7.5mm that the front sprocket will rest against. Since this output shaft does not use the locking tab and is just held in place by the bolt a thicker washer was used to take up the extra gap as the output shaft came through slightly. I used a wheel spacer that I had lying around to fill the gap.
https://photos.app.goo.gl/cgwjq43uhmyKn5yFAhttps://photos.app.goo.gl/JRvEv3JnsqzV6eV36https://photos.app.goo.gl/1oKhSrbdoYe64soQ6 The 78 cb750 f also has a wider swingarm, it is roughly 10 and 1/4 inches. I am not sure what other models have this type of output shaft and the wide swing arm but if you have them you can easily put a 160 tire on the rear.
The rear rim I am using is off an 03 Suzuki sv650. This rim uses a 20mm rear axle and because of this the stock Honda axle will be reused.
In order to gain clearance on the frame and engine case I switched to a 530 O-ring chain. The sprockets are set up to take the 530 chain.
The front sprocket I am using is made by PBI and as a 1/4 inch off set.
https://photos.app.goo.gl/ga6uXkx6smw2sju1Ahttps://photos.app.goo.gl/WVcpWjsJZfMHtrok8The rear sprocket is made by JT Sprockets. the part number is JTR829-48
I am going with a 16 tooth front and a 48 rear. I am not sure if a larger front sprocket will have clearance as things are pretty tight...
The sprocket side spacer off of the 03 sv650 will be used and this actually centers the wheel perfectly. it measures at about 18.5mm
https://photos.app.goo.gl/w9Zo66X3Cas71hsV7https://photos.app.goo.gl/MYzCLvKpm3Ma6s1A8Here is a machined straight edge to show the back face of the sprockets lining up.
https://photos.app.goo.gl/QEGV5cZh1V1KUJgc6Here is a photo showing the chain alignment.
https://photos.app.goo.gl/ScwXczoyatnN8gaVAThe rear axle needs to sit towards the back of the adjuster range to the sprocket bolts don't hit the swingarm. There is still plenty of room for chain adjustment.
I started with a 120 link chain and shortened it about 6 or 7 links.
Here is a photo showing clearance on right side between tire and swing arm. It is close but there is still plenty of room.
https://photos.app.goo.gl/d5F7q6ycPhHN4aps6The chain also clears all of the tubing on the frame with this set up. It is close in some areas but no rubbing and a few mm of space.
As far as the sprocket cover goes there was a "post" in it that I had to cut out when I was trying various sprockets. I had ordered a a front sprocket form cognito moto. They advertised a 3/8 offset sprocket (9.5mm) to do a wide tier swap. This DID NOT work for the 78 cb750f as the output shaft has the step mentioned earlier. And it did not measure 9.5mm offset but actually more like 11.5mm... the extra 2mm also caused the chain to hit the case. I am not ragging on cognito, they are a great company and I have used many of there products. It was when I was fitting this sprocket that I cut the post on the sprocket cover, This may or may not need to be done.
https://photos.app.goo.gl/mManZvo9VJsQfcaa8This post was originally made to show just the sprocket side as there are a variety of ways to do the caliper depending on what you chose to run, but I will outline what I did.
As far as the brake side goes that will be depending on what you choose to run for a caliper. I am sure that the caliper off the 78 cb750 could work but a bracket for it will need to be fashioned OR a custom rear rotor that is larger than the sv60. I can definitely say the arm that holds the caliper will not clear the tire. I have seen some people bend the arm to clear the tire but I went a different route.
I am using a brembo p34 rear caliper and a bracket I made for it, I am not going to write about this unless someone asks as you may have a different caliper you want to run. I basically used a plasma cutter to cut an outline...
I kept the sv650 stock brake spacer for my mount to sit against. And then filled the rest of the gap with what I think was originally a spacer for the 78 cb750 honda.
I hope this helps someone put a wide tire on their Honda.
