Author Topic: Tube popped because of exposure through rim vent hole - how to prevent  (Read 647 times)
Offline a188
Hello,
I ride a CB350F and found my rear tube slowly leaking a few days ago. The hole in the tube occurred in the exact spot where there is a "vent hole" in the rim (the left hole, near the yellow sticker):
I had a tube strip installed and it seems that sunlight/chemicals/dirt wore through this specific spot in the rim strip (at the end of the Sharpie):
Which then created this hole in the tube:
From the outside, when the tube was leaking, this was my perspective (with tube strip installed):
My front rim doesn't have one of these vent holes and the tire and tube seem to be doing fine. Can I prevent this issue in the future on my back rim somehow? Is there something I could use to cover up the hole?
Offline CaptFatCat
I always thought those holes were for rim locks.
Resurrecting a Herman Munster CB750 from a few old baskets of K2 and K7 parts.
Offline BenelliSEI
  • 1969 cb750
Yes.... and none of my cb’s (400F, 550K and 750K/F) ever had any “vent holes”.
« Last Edit: June 22, 2021, 05:38:22 AM by BenelliSEI »
Online bryanj
Called security bolts or locks in UK, used to be common on British bikes
Never seen rim lock holes on any 1970's sohc4's, but I don't know the 350's at all.  Is it possible that is the incorrect rim?
Offline a188
It may be the incorrect rim, but I often ride off-pavement, so getting a rim lock will be a great investment  ;)
Just purchased a rim lock and I'm thrilled to get back up and running. Thank you each for your advice
