Author Topic: Street 750 looking for drag strip advise  (Read 5612 times)
« on: June 28, 2021, 06:05:42 PM »
 I hope to get my bike on the track sometime this year, I never have drag raced on a bike but have been 7.50's at 177 in a car.  Need a new helmet first.
  It's a 70 with a K3 motor, mildly ported, 836 kit, KH/K cam, APE springs and retainers, Yamiya 4-4 repro no number pipes, I'd drill the baffles or remove them but won't cut them off. 70 carbs with stock jets.  I have a 17" Shinko on an A rim that could bolt on in place of the 18" Lester/Dunlop. 17/48 sprockets.
 Any advise on launching, setup or other tips from guys that have done it on a mostly stock frame? I feel the need to get a time slip. Because, I ain't getting any younger.
  I knew a guy that had pegs on the swingarm, laid over the tank and shifted with his left hand. I'm not that adventurous but I do own his bike from which I'll borrow the seat and gas tank.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Street 750 looking for drag strip advise
« Reply #1 on: June 28, 2021, 06:46:49 PM »
You will have a blast! Get out for test and tune at the local track to get an idea how it behaves. My K8 has a similar setup, although I'm using the flat top C.I. 836 pistons so my C.R. is probably near stock. Running 16/52 sprockets which makes the front end VERY light but I have been able to calm that somewhat by spacing the forks about 1-3/4" lower and fitting an 81' CB750 swingarm which adds about 2" to the wheelbase. Best run so far has been 12.90 around 101mph pushing 9500rpm at the finish line. Using heavy springs and retainers as well. I will do a short burnout only to help bring the cold natured beast up to operating temp... plus doing burnouts is half the fun!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dragracer
  • CB750F Dragbike
« Reply #2 on: June 28, 2021, 09:19:26 PM »
I've had more fun with a short wheelbase bike with a stock engine than  some of my faster/quicker full tilt dragbikes. Prior to building my long wheelbase F3, i used to race my stock K8 in street ET. I learned quickly that you have to develop smooth clutch/throttle skills if you want to lower your 60' while also keeping the front wheel on the ground. I can't remember the gearing I put on it but it was pretty stout, because i mainly used the bike to commute around the city of Houston and wasn't concerned about freeway speeds so in reality, it already had drag race gearing.
Because i knew the bike had a lot of low end torque, I knew the bike had to be set up so my riding position was conducive to a hard launch. I lowered the bike by sliding the fork tubes up in the triples, i replaced the stock exhaust with a used sidewinder from a CB1100F to get more ground clearance. I made a set of short, adjustable struts and located a spare seat and  had it cut down to lower my body into the frame more and lock my body forward and in place. I also added a set of dragbars to allow my body to lean forward. getting as far forward on the bike as possible to put more weight on the frontend to help combat wheelies. Put your feet as far forward as you can when rolling in the beam. Your legs will naturally swing backwards to the pegs so you can be ready to foot shift the bike. The rest of the pass is easy once you launch the bike.  Like the car, just hit the shift points and tuck in for the ride.
I would suggest you buy a set of short shocks and not use struts. I only used them at the time because i didn't know any better. You want the suspension to work properly. Be certain your front forks are not spongy. If they are leaking, put new seals in and heavy weight oil to stiffen them up. Ideally, Lowering them internally with a spacer and stiffening them up would be best.  You want the center of gravity of the bike as low as practical without bottoming it out. A sidewinder exhaust helps to get the clearance you really need. It might be best to preserve those nice 4-4 pipes and not drill them out.
At the track, My method was to bring the rpms up at the line and then finesse the clutch lever to get the bike moving. The key is not to throw the lever away, but slide it out as much as possible to get the bike moving as quickly as you can and not cause it to wheelie. YOu don't want to drag the clutch too long but you also want to lock the throttle wide open as fast as practical.
The key for me was to practice my launches on the country road near my home. My goal was to learn to launch the bike as hard as possible without spinning the tire on the unprepped street. Once i felt i had perfected that feat, I was ready for the dragstrip and it really paid off. Just keep one thing in mid, do not over ride your skill level- just like racing the car.
Offline johno
« Reply #3 on: June 29, 2021, 01:16:41 AM »
love that launch Wilber  ;D  that has to be the happy snap of the month  8) 8) 8)
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
« Reply #4 on: June 29, 2021, 03:50:20 AM »
VERY happy! This was round 2 back in the spring of 2018, my opponent had broke in the water box so I had a bye run. I was "all in" trying to get a good R.T. for the potential bye in the next round! Didn't work though, but I did get all the way to the fifth round before being eliminated.  8)
TAMTF...
Wilbur
Projects:
« Reply #5 on: June 29, 2021, 09:41:07 AM »
 Thanks, I'll reserve a couple of those tips for the Drag bike I want to assemble next, and use the easy ones on this street bike.
Offline dragracer
  • CB750F Dragbike
« Reply #6 on: June 29, 2021, 12:12:24 PM »
Lol. Those were tips from my "Street bike".
« Reply #7 on: June 29, 2021, 06:27:28 PM »
Don, learn to launch before you mess with some nice pipes...or just put any other pipe on the bike.  Good launch skills are gonna make the difference more than any bike mods.  Launching is hard.  Dragracer is right, it takes lots of practice.  All I know is that I am still really bad at it. lol   But don't be afraid to go have some fun at a test and tune.
« Reply #8 on: June 29, 2021, 06:50:24 PM »
 I'm thinking just a T&T at a Super Comp race we are already going to. I built a nice bike rack in the race trailer.
   The Drag Bike project was really a bar hopper/drag racer/street freak when the PO owned it.
 My first burnout on a good track in the front engine dragster was at Memphis,  I was in high gear in the water and saw the shift light come on, just as I lifted, it caught traction the slicks ripped and it left my stomach 50 feet behind me. That's when I knew where the term slingshot Dragster came from.
  I did an accidental street launch 15 years ago after 20 years off a bike, my problem child 750 bogged, I got annoyed and cranked full throttle, still not sure how I stayed on it, that's why I asked.
« Last Edit: June 29, 2021, 07:01:06 PM by Don R »
« Reply #9 on: June 30, 2021, 04:14:45 AM »
The seat I'm using now has had the driver portion cut down out about 1-1/2" to 2". I had a couple hard launches with the stock seat that taught me the value of a physical barrier to prevent sliding off the back! I never fell off but it was a little unnerving...
TAMTF...
Wilbur
Projects:
Offline Tracksnblades1
« Reply #10 on: June 30, 2021, 06:08:36 AM »
Responding to your “or other tips”….
Plenty of money 💰💰 💵 😜
Age Quod Agis
« Reply #11 on: June 30, 2021, 09:45:01 AM »
 The humpback seat will go on it for sure. It's a few minute swap.
« Reply #12 on: June 30, 2021, 02:23:35 PM »
[/quote]
 Understood, the reason the drag bike is not running is it's mystery rotating tight spot and the $$ drain caused by the Super Comp car.
Offline dragracer
  • CB750F Dragbike
« Reply #13 on: June 30, 2021, 09:26:28 PM »
I bought an extra seat off Ebay and had it reupholstered with the front section cut down. In hindsight I wish I would have moved the cut out further forward to bring my weight towards the front end. This picture was taken after it sat in the corner of the shop for 10 years so it rusty and crusty looking.
« Last Edit: June 30, 2021, 09:29:22 PM by dragracer »
« Reply #14 on: June 30, 2021, 11:49:28 PM »
[/quote]
Kenny has the tool to fix the tight spot. He’s one of the few that has mentioned the green cases. Falicon may have been the original.. I let that tool get away when our local guy passed away. 😩
« Last Edit: July 01, 2021, 12:34:35 AM by Tracksnblades1 »
Age Quod Agis
« Reply #15 on: July 01, 2021, 08:03:40 PM »
And what would that tool be? What do you mean by green cases? Don's welded stroker crank doesn't run true on the main journals, which is why it has a tight spot.
« Reply #16 on: July 02, 2021, 08:12:26 PM »
 Actually,  I've dial indicated the crank while laying in the mains and found no wobble. My former machinist checked it too but I no longer have total confidence in his work. I could rotate the motor easily after bolting the cases up. I did not however, continue to check it as other items went on.
  My new plan is to remove items and check as I go. I expect to find a bent rod. The cylinders may tell a story too.
« Reply #17 on: July 02, 2021, 10:09:14 PM »
I'm sorry, I thought I recalled that the crank got tight once the case halves were torqued down?
Offline bear
  • Leeton in Australia
« Reply #18 on: July 03, 2021, 05:14:08 PM »
I would like to dip into my vast knowledge of drag racing techniques to help you out Don but I can't, I don't have any.
But I do have one tip that I bought over from my speedway days to my road racing that served me well.
It will help you dodge the dreaded Honda bog down then wheel stand syndrome. ;D
It's basic and I would think common knowledge,  but sidecars have an unnerving tendency to turn 90deg to the left when they wheel stand and I've lost count the number of times we've been wacked off the start line. So there must be a few riders around that haven't worked it out therefore I'll mention it.
Load your clutch up at the line.
Cheers
Brian
« Last Edit: July 03, 2021, 08:11:29 PM by bear »
Offline johno
« Reply #19 on: July 03, 2021, 11:10:01 PM »
Nice tip Bear  8)
Did you ever load it up too much and hang yourself on the tapes lol
« Reply #20 on: July 04, 2021, 01:09:55 PM »
  No worries, I was counting on finding a 900 this morning, alas it's a 736 so maybe it time to have another look with my local sohc mentor looking on.
Offline johno
« Reply #21 on: July 04, 2021, 11:38:51 PM »
SAM , where are you ! you old dog, Donny's looking for a few tips. I reckon you should come out of retirement and do some mentoring. ;D
Offline bear
« Reply #22 on: July 05, 2021, 09:19:24 PM »
Nice tip Bear  8)
Is the Pope a Catholic? ;)
Cloth tape was fine but some tracks used nylon (it was cheaper) and you would end up like a blowfly in a spiders web.
« Last Edit: July 05, 2021, 09:24:20 PM by bear »
« Reply #23 on: July 27, 2021, 11:36:44 AM »
 I ordered a new helmet just now so no excuses for not making a pass on a bike this year. The only question is cb750 or KZ1000. I'm wanting the CB836 time slip so I'll begin  there.   We have a Super comp race in August at Byron Il. and another in Sept.
 I confirmed the 17/48 and the chain has low miles. I'm checking my other bikes for better ratios.  My MO is usually 18/48.
« Last Edit: July 27, 2021, 03:59:19 PM by Don R »
« Reply #24 on: July 27, 2021, 07:25:38 PM »
17/48 is MUCH better Don. No sense in going through the trap in 3rd or 4th. Use the power.
