Author Topic: CB550 hub and Borrani rim  (Read 1173 times)
Offline dkihlgren
« on: June 29, 2021, 06:17:01 AM »
I’m trying to lace a rear wheel with a 550 hub and Borrani aluminium rim. Should I have standard spokes or do I need custom length?
Skickat från min iPhone med Tapatalk
Re: CB550 hub and Borrani rim
« Reply #1 on: June 29, 2021, 06:24:32 AM »
Thats a very good question to which i dont know at the moment but i do have a standard and a Borani type(not sure on atual make in my gagage so will measure and report back asap. May be a couple of daysas garage is a way off!
Offline dkihlgren
« Reply #2 on: June 29, 2021, 06:25:28 AM »
That would be awsome!
Offline Alan F.
« Reply #3 on: June 29, 2021, 10:42:20 AM »
You'll need the 'effective rim diameter' to calculate your correct spoke length for your hub.
Here's a link with a very good explanation and a spoke length calculator that works well:
http://earlymotor.com/leon/misc/html/spoke.htm
Offline dkihlgren
« Reply #4 on: June 29, 2021, 11:13:12 AM »
Thanks! I used another calculator and got about 5mm to long spokes. Exactly the difference with earlymotor-calculator. $40 wasted…
« Last Edit: June 29, 2021, 11:27:02 AM by dkihlgren »
Offline Alan F.
« Reply #5 on: June 30, 2021, 08:10:59 AM »
Yup. Before I used this calculator I vetted it by measuring a couple of stock Honda setups, it was good to 1/2 mm which was probably due to my measuring error.
There are ebay sellers that sell spokes made to your spec, gauge and length, but I suspect end angles will differ from stock. I'll try them eventually.
« Reply #6 on: June 30, 2021, 09:50:49 AM »
So you are saying a Definite difference in diameter .. where the spokes enter the rim ?
« Reply #7 on: July 02, 2021, 11:33:08 AM »
Years ago, I put one on the front of one of my cb750s and used the stock spokes. Added washers under the nipples (like those used on my GL1000). Then  ground the extra spokes off at the nipples where they poked out a bit, under the rim band. Bit slow, but worked well.
Offline Alan F.
« Reply #8 on: July 02, 2021, 07:17:34 PM »
I'm not ignoring you Frank, just not sure if you were talking to me or what you mean.
All rims are different.
« Reply #9 on: July 03, 2021, 12:04:06 AM »
Mines a 500 and not sure what make of alloy rim but spoke are definately shorter on the alloy rim(cant find my measuring stick had to use string!)
