Author Topic: 550 key turn does nothing  (Read 1241 times)
Offline exponent
  • Obsessed
« on: June 30, 2021, 09:07:02 PM »
Went to test something on my 78550 and turning the key does nothing, not the first time this has happened but now I can't figure it out. battery is 13v starter solenoid is 13v, is the barrel busted?
'78 550K 2106630
Offline goodtryer
Re: 550 key turn does nothing
« Reply #1 on: June 30, 2021, 09:52:33 PM »
check the fuses first. if those are ok, get out your wiring diagram and start tracing voltage with a multimeter. the contacts inside my key switch had loosened up over the years and i had a completely dead bike a couple of months ago. stopped for gas and when i went to start up again, nothing, no lights , no power. found the loose connections after some sleuthing.
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
« Reply #2 on: July 01, 2021, 03:35:33 AM »
The 78 in uk was notorious for the conector pulling off the switch and the electrica bit failing, at one time you could buy just the electrical part
Offline exponent
  • Obsessed
« Reply #3 on: July 01, 2021, 08:37:51 AM »
Fuses all good, the switch inside the key barrel? I'll have to open it up and see. Not getting any voltage when I try to read the connector plug to key barrel either
'78 550K 2106630
Offline exponent
  • Obsessed
« Reply #4 on: July 01, 2021, 10:21:53 AM »
Here's the switch
'78 550K 2106630
Offline goodtryer
« Reply #5 on: July 01, 2021, 10:29:23 AM »
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline exponent
  • Obsessed
« Reply #6 on: July 01, 2021, 10:51:58 AM »
http://forums.sohc4.net/index.php/topic,61168.msg2155413.html#msg2155413
There's a pic of what I did at the link.
Ok, mine are all tight nothing loose on the connector, it might be somewhere else
'78 550K 2106630
Offline goodtryer
« Reply #7 on: July 01, 2021, 11:05:50 AM »
Be sure to clean all of the contacts as you are going through the electrical connections.
I use a brass cleaning brush from a gun cleaning kit for the female bullet connectors and scotchbrite/steel wool/etc to clean the male connectors. Also clean those contacts on the rotating parts.
Don't overdo do it. Just enough to remove the dirt/grime/gunk. Try not to remove any of the metal or finish.
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline exponent
  • Obsessed
« Reply #8 on: July 01, 2021, 11:23:54 AM »
Almost certain it is somewhere else but don't know where, not getting any power on the red wire from the connector that goes into the ignition barrel, getting power in other places I'm checking with red but I can't seem to follow it, any ideas???
'78 550K 2106630
Offline Deltarider
« Reply #9 on: July 01, 2021, 11:59:11 AM »
How about consulting the wire diagram for your specific model? It's in the last pages of the Owner's Manual: http://manuals.sohc4.net/cb550/owners_manual/OM55078.pdf. Also, are you aware that of the five fuses, two are just spares? In other words, are you sure a good main 15A fuse is in the right socket?
CB500K2-ED Excel black
« Reply #10 on: July 01, 2021, 01:09:22 PM »
How did you check the fuse?  A visual inspection is not the proper way.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #11 on: July 01, 2021, 10:26:03 PM »
+1
Volt ohm meter
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline exponent
  • Obsessed
« Reply #12 on: July 03, 2021, 10:01:29 AM »
Fixed it, was the fuse
'78 550K 2106630
« Reply #13 on: July 05, 2021, 12:24:36 PM »
Gotta love those easy fixes!
