Author Topic: transparent carburetor video  (Read 584 times)
« on: June 30, 2021, 02:48:55 PM »
 I saw this on cb750 Facebook, very cool.
Re: transparent carburetor video
« Reply #1 on: June 30, 2021, 02:57:07 PM »
  This is an eye opener. I've seen a foamy float bowl on a Jr. Dragster motor with a Lectron plastic fuel bowl. It was amazing, the Lectron came with a foam fuel stabilizer around the main jet needle. I could see why.
  I'd love to see more circuits at work. You can also see reversion in a few shots that they don't mention.
« Last Edit: June 30, 2021, 03:00:14 PM by Don R »
Offline Alan F.
« Reply #2 on: June 30, 2021, 03:49:04 PM »
Great video, thanks for posting.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: June 30, 2021, 10:53:24 PM »
This may come across as cynical.  Even though i'm a smarter every day fan.  Maybe someone else thought the same as me.
Actual rocket scientist agrees not to run gasoline through transparent replica carburetor.  Proceeds to team build a non functional (but incredibly high tech) educational model.
Rather than simply using water.
« Reply #4 on: July 03, 2021, 02:37:50 AM »
like ive always said,dont get to fussed about float levels settings,its a washing machine inside the bowl,hard braking,lean angle bumps etc,fuel level is splashed all over on a dirt bike?
Offline 333
  • Time for change
« Reply #5 on: July 05, 2021, 08:04:21 AM »
It's kinda sad that a "mechanical engineer"  A) doesn't know how a carb works, but more importantly, B) uses terms like "turny thing" and "floppy-do".  I had to stop watching it there.
But then I went back and skipped ahead, because I liked the idea of actually seeing the carb in action. Because I skipped ahead, I may have missed it, but I'm surprised it worked at all, given I didn't see a vent for the fuel bowl. Fuel ain't coming in if the displaced air doesn't have an escape route.
Not bad.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
