Author Topic: Maui Z1 1973  (Read 79928 times)
Re: Maui Z1 1973
« Reply #650 on: December 14, 2021, 09:38:38 AM »
I could not resist to search for circuit diagrams. Then continued to Google "Z1-900 circuit diagram + brown" searched brown white  too.
You are not alone wondering about these wires. Not only 900 the later 1000 as well.
"I too have an extra brown female and extra brown/white female coming out the top of the loom."
https://kzrider.com/forum/4-electrical/608408-wiring-inside-headlight-bucket
Not an absolute answer here but it must be explained in another thread.
Here another model, might be same function. Read all, last post might be a correct answer.
https://www.kzrider.com/forum/4-electrical/504973-what-s-the-brown-white-wire-do
Measure the voltage with power on and test various controls. Brown might be 12V as black is on a CB750?
The stock diagrams are more complete than later colored when describing CB750, maybe same with Kawasaki Z1-900?
« Last Edit: December 14, 2021, 10:03:01 AM by PeWe »
Re: Maui Z1 1973
« Reply #651 on: December 14, 2021, 12:55:23 PM »
I’ve seen where some bikes have a tail stop lamp out warning light, it may have something to do with that. I may change the headlamp over to one with a city bulb like the UK bikes got, some day.  My sealed beam was blown and I went to the parts store to get a replacement. I noticed they actually sell an LED equivalent for that sealed beam. I did not get one but that’s interesting. It was $154.
Re: Maui Z1 1973
« Reply #652 on: December 14, 2021, 01:36:48 PM »
I'm glad you didn't Steve, I'm not a fan of LED lights on old bikes, they look weird. ;D
Re: Maui Z1 1973
« Reply #653 on: December 15, 2021, 06:54:35 AM »
I tested LED in the rear on my K6. Did not work, bad light to plate.
Front LED H4 work fine. Very bright white make me to be noticed in traffic much better than std H4 my bike has as stock. Take less power too, around 35W.
Re: Maui Z1 1973
« Reply #654 on: December 15, 2021, 05:06:57 PM »
I used a long fiber optic cable from the tail bulb to the instrument panel. Then I just melted the end of the fiber at the instruments' end and held it in place with a cheesy bracket I made. Then when the taillight was ON, I could see a little bright spot on the dashboard.
Re: Maui Z1 1973
« Reply #655 on: December 16, 2021, 07:06:17 AM »
Very resourceful, I would not have thought of that.
Re: Maui Z1 1973
« Reply #656 on: December 16, 2021, 02:03:57 PM »
Another dumb question
How do the two bowl vents route?
I assume the 4 overflow lines bunch up and drop over the rear of the engine to the swing area area.
Thank you all and Melekalikimaka
Re: Maui Z1 1973
« Reply #657 on: December 16, 2021, 03:16:26 PM »
I can't help you there Steve, I'm building my Z1-B from parts. One of my favourite Christmas movies, keeping ol' Bing's song alive. ;D
Re: Maui Z1 1973
« Reply #658 on: December 16, 2021, 03:20:48 PM »
Lol  :D  Terry you'll be having another Tropically warm Christmas !
Online Stev-o
Re: Maui Z1 1973
« Reply #659 on: December 16, 2021, 03:27:20 PM »
Yes, they run down in front of the swing arm
Re: Maui Z1 1973
« Reply #660 on: December 16, 2021, 03:41:07 PM »
Yeah Bill, if I'm lucky it'll be in the 70's on Christmas Eve for our family BBQ (around 30 guests) and the same for Christmas Day at the MIL's place, hopefully not in the 90's, or higher. No pool like the Griswolds, though. ;D
Re: Maui Z1 1973
« Reply #661 on: December 17, 2021, 06:54:10 AM »
How about the bowl vents that need to go up?
Online Stev-o
Re: Maui Z1 1973
« Reply #662 on: December 17, 2021, 08:04:59 AM »
Mine go slightly up, back and then tuck in behind the airbox plenum.
Re: Maui Z1 1973
« Reply #663 on: December 17, 2021, 01:03:00 PM »
Thank you.
Re: Maui Z1 1973
« Reply #664 on: December 18, 2021, 05:57:50 PM »
Today I made some progress. I’m splitting my time between a major front yard upgrade and the Z1.
I got oil into the forks which is easy and I learned I needed to fold the handlebars down to get the caps back on. No biggie. I had to fix a cold solder on the rear break light switch, I installed the kick starter and I filled it with oil and did a cold crank, no plugs, to see if oil pressure would come up. It took some long seconds gritting my teeth but the oil light went out! Thereafter it went out quickly. I just wish it was easy to peek under the valve cover to check the top end. Next I’ll get the exhaust system on, recheck the ignition, set up the temporary fuel and try to start it. These are nervous times.
Re: Maui Z1 1973
« Reply #665 on: December 18, 2021, 06:03:10 PM »
Re: Maui Z1 1973
« Reply #666 on: December 18, 2021, 06:03:54 PM »
I guess I need to get my daughter to help, the video link isn’t working.
Re: Maui Z1 1973
« Reply #667 on: December 18, 2021, 06:04:14 PM »
Nice, congrats!
Re: Maui Z1 1973
« Reply #668 on: December 18, 2021, 06:04:42 PM »
Link is working for me now
Re: Maui Z1 1973
« Reply #669 on: December 18, 2021, 06:22:00 PM »
Looks fantastic Steve, well done! ;D
Re: Maui Z1 1973
« Reply #670 on: December 18, 2021, 06:26:26 PM »
Waiting for the air filter plenum clamps, I didn’t get the right ones. They didn’t come on the bike and I ordered the wrong part number.
Offline Alan F.
Re: Maui Z1 1973
« Reply #671 on: December 18, 2021, 06:38:47 PM »
That is a milestone, congratulations.
Re: Maui Z1 1973
« Reply #672 on: December 18, 2021, 06:55:25 PM »
Excellent  ;) :) progress so far Steve.
« Last Edit: December 19, 2021, 12:11:40 PM by grcamna2 »
Re: Maui Z1 1973
« Reply #673 on: December 19, 2021, 07:55:23 AM »
I noticed the tach didn't bump or anything. I guess it wasn't turning fast enough, I hope. New tach cable, I felt movement in it I think.
I worry too much.
Offline Alan F.
Re: Maui Z1 1973
« Reply #674 on: December 19, 2021, 08:12:58 AM »
I'd agree it probably cranking too slow for the tach to register.
