Author Topic: Maui Z1 1973  (Read 74577 times)
Re: Maui Z1 1973
« Reply #1000 on: December 12, 2023, 10:42:00 AM »
I like what dragracer said in reply# 998 "let me know what you find under that bolt"  ;)
Re: Maui Z1 1973
« Reply #1001 on: December 12, 2023, 02:08:56 PM »
I will look again, I don’t mind saying, for a simple system, this has had me stumped, I’m not used this sort of thing, I’ve done troubleshooting on some very complex stuff, very frustrating.
Offline dragracer
  • CB750F Dragbike
Re: Maui Z1 1973
« Reply #1002 on: December 12, 2023, 05:23:50 PM »
I failed to glean exactly what your oiling issues are for the engine.  Are you not getting oil to the cam bearings up top. ?? I'm sure you're aware of the path the oil flows in the kz engine. I'd start by removing the oil plug in the galley on the top case and then work from that point to the oil send.ing unit housing to verify no obstructions. Just unbolt it and look at the passages fror trash or anything stopping the flow of oil.. From there i would confirm the oil holess near the studs are free. I would also determine if the oil passages on the cylinder itself are unobstructed. Gasket sealer can somes restrict fliw to the head. I don't know if this is a stock head or not. I would then concentrate on the outside holes on the head where the oil goes into the cavity feeding the cams. That galley crosses through the head between the exhaust and
 intake side. Oil drains back out through the cam chain tunnel. And don't neglect looking at your oil filter bolt. There a check valve inside of it as well that could impact pressure.
Re: Maui Z1 1973
« Reply #1003 on: December 13, 2023, 07:07:49 AM »
Thank you, the galleries have been visually checked and air checked. I've even puffed air up from the oil filter outlet and used a feather to verify air puffing out of oiling holes and the cam bearings.
I'll update when I finish assembling it.
Re: Maui Z1 1973
« Reply #1004 on: December 13, 2023, 02:46:09 PM »
Would be nice if you have a pair of low-quality/used camshafts and rockers to install,just for test purposes,to see if they get a bunch of good oil flow?
You can save your NOS cams until after this is sorted..
Re: Maui Z1 1973
« Reply #1005 on: December 14, 2023, 07:13:17 AM »
I have two sets of cams, one is a little better than the other, no rockers on this head, it's shim on top of buckets,  fairly fiddly getting set up.
Re: Maui Z1 1973
« Reply #1006 on: December 14, 2023, 11:10:15 AM »
Okay  :)
Re: Maui Z1 1973
« Reply #1007 on: April 14, 2024, 03:42:36 AM »
Any headway?
Re: Maui Z1 1973
« Reply #1008 on: April 14, 2024, 02:18:06 PM »
Come on guys, the first rule of Bike Club, is you don’t mention stalled projects. I have several…. ;D
Re: Maui Z1 1973
« Reply #1009 on: April 14, 2024, 08:24:32 PM »
Fight club was in his head, or the one guy was...
Re: Maui Z1 1973
« Reply #1010 on: April 14, 2024, 08:29:31 PM »
Life happens, are you enjoying life? If not, how can you correct things to return some enjoyment? Being purposeful can sometimes help but too easy to let life fill your day with meaningless stuff and drift from one to the next. Sometimes depression robs you of motivation, and sometimes you can not enjoy the projects because other higher priority more important things take all you time or energy.
Not trying to be a PITA by asking, just curious... Maybe he is out exploring in his Honda Acty and enjoying the new toy...
Re: Maui Z1 1973
« Reply #1011 on: October 04, 2024, 08:41:36 AM »
Coming up on a year, any update?
Re: Maui Z1 1973
« Reply #1012 on: October 04, 2024, 02:19:48 PM »
How's that KZ doing ?
