Author Topic: CB750A Hondamatic sharp metallic clinking and clanking  (Read 6552 times)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: CB750A Hondamatic sharp metallic clinking and clanking
« Reply #25 on: September 21, 2021, 07:17:05 PM »
***Coan Engineering UPDATE*** got a call from Todd. He said they can for sure machine and get the stall speed up on the tc I sent in! I told him there is a handful other knuckleheads looking to do the same!
Offline kmb69
« Reply #26 on: September 22, 2021, 06:26:28 AM »
Awesome!
Many Thanks
« Reply #27 on: September 22, 2021, 11:38:13 AM »
That is awesome. I wonder if they would be able to approximate the stall by how much (and how) material is removed from the stator.
  • Gusto mo titi ko?
    • project
« Reply #28 on: September 22, 2021, 02:03:11 PM »
Just out of curiosity, what stall speed are you guys after?
Online Don R
« Reply #29 on: September 24, 2021, 04:30:37 PM »
 I noticed a few inexpensive converters on ebay in case anyone needs adjustment. I may save my A case for a while.
  • Gusto mo titi ko?
    • project
« Reply #30 on: September 24, 2021, 07:33:09 PM »
Looks like they can loosen up about 500 rpms without extensive machining.
Online Don R
« Reply #31 on: September 30, 2021, 04:36:38 PM »
 That's a good number. Cam accordingly. Fill us in on the details when you get it back.
« Last Edit: October 17, 2021, 11:35:35 PM by Don R »
Offline jukku
  • Happy with my Hondamatic
« Reply #32 on: June 22, 2022, 12:16:52 PM »
Hello
The third of my CB750A Tomatics started clinking and clanking. I´ll drive this summer with the "accompaniment" from the gearbox. It is a feature not a fault. ;-)
Have to find two of the gaskets that I´m missing.
The clutches tend to slip a bit when I hit the throttle, too much torque with with 836 10:25 Wisecos, K7 carbs, F2 cam advanced a bit?
  • Gusto mo titi ko?
    • project
« Reply #33 on: June 22, 2022, 02:21:53 PM »
Clutch parts are available; they are the same as the Honda cvcc
« Reply #34 on: June 26, 2022, 04:06:24 AM »
Hello
The 836 shouldn't be the slipping problem as there have been many of the automatic 750s drag raced.
Exactly what oil do you have in it?
Offline jukku
« Reply #35 on: June 30, 2022, 12:17:49 PM »
Gulf single 40 used in classic cars.
Temperature is now about 30 degrees celsius.
Offline jukku
« Reply #36 on: July 15, 2022, 11:13:10 AM »
The source of the CB750A Hondamatic sharp metallic clinking and clanking
http://forums.sohc4.net/index.php?action=dlattach;topic=99952.0;attach=411532
Page -6-
Fig. 5
Stopper Pin and Regulator Valve Drive Arm acts as "anvil and hammer".
It is not a fault, but a characteristic. ;-)
Offline TdLpps
« Reply #37 on: July 15, 2022, 01:25:26 PM »
Great document.  Thanks for attaching to the thread.
