It definitely wasn't as warm today as it was yesterday, but hey, it's Saturday, and it wasn't raining, so not a total loss. One of the jobs I haven't done on the auto is to connect the rear blinkers, so after I went as far as I could with the Suzuki T500 seat, I decided to sort the blinkers. Now once again, the problem appears to be that Vik, or someone else decided to remove the grab handle off this bike and maybe use it on his other CB750A, so cut thru the blinker wires and dropped them off the bike.
CB750A grab rails in good condition must be as hard to find as kick starter pedals, so I had to come up with a redneck plan. I had some spare K0-K3 blinker brackets, but of course they don't fit the later suckers with their big fat mounts. Hmmnn, I came up with a plan. First of all, I mounted the splined tube, which is surprisingly thick, in my lathe.
Terry’s Taxi blinkers Sat 14 Aug 2021 by
Terry Prendergast, on Flickr
Then I chopped the brackets off. The OEM steel is super hard, my hack saw didn't scratch it, so I had to employ the angle grinder.
Terry’s Taxi blinkers Sat 14 Aug 2021 1 by
Then I bored the end out and cleaned it up a tad.
Terry’s Taxi blinkers Sat 14 Aug 2021 2 by
Coincidentally, the mounting tube is a tight fit over the K0-K3 mounting tube, so I used my vice to force one into the other.
Terry's Tax1 blinkers Sat 14 Aug 2021 by
Unfortunately, once I mounted the blinker bod and gave it a twist into place, the mounting tubes moved, so I had to drill and tap them for 6mm screws.
Terry's Tax1 blinkers Sat 14 Aug 2021 1 by
Terry's Tax1 blinkers Sat 14 Aug 2021 2 by
I used a couple of those wonderful heat shrink connectors to repair the cut wires, and assembled the blinkers onto the bike. Looks factory! (sort of....)
Terry's Tax1 blinkers Sat 14 Aug 2021 4 by
I thought I'd check to see if they worked, and was happy that they did, but disappointed that the front blinkers weren't blinking? I pulled the front left apart, and found this:
Terry's Tax1 blinkers Sat 14 Aug 2021 5 by
If you were ever idly wondering what would happen if you didn't replace the lens gasket on your blinker, well, wonder no more. Moisture gets in, and fcuks them. The other front blinker was fine, just missing it's bulb. Luckily I never throw anything out, and I had a similar blinker that had been down the road and ground away somewhat, but the guts were still good.
Terry's Tax1 blinkers Sat 14 Aug 2021 6 by
But by this stage I'd done enough, and needed something to eat and drink. Tomorrow is supposed to be almost warm, so should be a good day to finish it. More then.
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
Terry's Tax1 blinkers Sat 14 Aug 2021 7 by
