Author Topic: starting gear  (Read 738 times)
Offline _mark
starting gear
« on: July 24, 2021, 11:19:35 AM »
Hi. I don't understand why the idle starting gear is free to shift on its shaft but not desingaging nor from the fly wheel and from the starting motor ... Anything wrong? thanks
« Last Edit: July 24, 2021, 11:21:19 AM by _mark »
Re: starting gear
« Reply #1 on: July 24, 2021, 12:24:09 PM »
You have to pull the shaft out
Re: starting gear
« Reply #2 on: July 24, 2021, 01:28:55 PM »
 The start clutch is in the big gear if that's the question. The shaft often comes out with the sidecover, the gear is a little fiddly to get in and out but once past the gasked it's easy,
Offline _mark
Re: starting gear
« Reply #3 on: July 24, 2021, 01:31:12 PM »
Well may be i didn t explained well myself. Question is not how to remove, but how it works because the flywheel is always connected to the starting engine shaft. I was expeting an engaging/disengaging mechanism Thanks
« Last Edit: July 24, 2021, 01:40:14 PM by _mark »
Offline kerryb
  • Not a very
Re: starting gear
« Reply #4 on: July 24, 2021, 02:04:12 PM »
The engaging/disengaging mechanism is in the big gear.  I suggest you move the parts (rotate) with a wrench and your fingers, then you will discover how it works.  The big gear has the starter clutch in it.
Re: starting gear
« Reply #5 on: July 24, 2021, 02:54:58 PM »
Not strictly true, the mechanism is bolted to the back of the rotor and the big gear freewheels one way but locks the other
Offline _mark
Re: starting gear
« Reply #6 on: July 25, 2021, 04:30:24 AM »
That's clear. thanks for the help.
