Brake parts assembly fluid is intended exactly for the purpose you describe.
You should flush/clean all the brake fluid from the unit and reassemble with the assembly fluid.
Then, put the Master Cylinder in a plastic bag with a small bag of dessicant, seal and shelve.
The MC will be ready for use whenever you'd like put it back in service.
