Author Topic: cb750k 4 float float bowl drainage gasket  (Read 400 times)
Offline D DIAMOND
« on: July 31, 2021, 07:55:44 AM »
hi does anyone know the exact size of the floatbowl drainage gasket on the early cb750 is it a o ring or some other material
Re: cb750k 4 float float bowl drainage gasket
« Reply #1 on: July 31, 2021, 04:13:57 PM »
 How early we talking ? On the 71-76 round top carbs I use a 3/32 o-ring for the drain plug. Getting the old drain plugs out can be kind of hard sometimes the first time if they have been in there forever. Good fitting screwdriver and some heat can work well and doing them while still mounted on the carbs offers a better perch.
