Thanks maxheadflow, I appreciate it!
The oil meter jets that go under the cam are there, free and clear. HOWEVER, the orings that go on the other end with a blocked passage are not there!? How important are those little bastards!?
I wonder if that was letting oil....
That would explain low pressure .
The smoke on start up and all the carbon build up in the chambers and on pistons is still puzzling. As is the smoking breather...
On more of a bummer not I checked ring gap, as someone above was curious.
Top ring was .020 on all
Second ring was .031 on all
Which I think is fine. But I snapped the second ring on piston 1 and 2! I was being super gentle!! Grrr...
Now new rings and a hone to the list...
Guess I am starting all over with this one! Haha well almost!
Plugged metering jets would not cause an issue, but bored out ones could. Possibly the wrong ones? I was thinking too much oil is making it through the jets causing the oil orifices in the cam towers to spray not dribble..
Missing O rings on the ends could allow oil to leak out. Might be part of the issue but I really don't know on that one.
Smoke on start up is typically caused by leaky valve seals but if the motor was filling up from a leaky check valve in the pump, it might cause the issue.
The ring gap is of concern. First off, I'd expect the gaps to be about the same. Spec on new stock pistons/bore is 0.008 to 0.016" and 0.028 as worn out. I would imagine an 836 kit might have looser tolerances but 0.031 is excessive.
This makes me question your leak test. If you are using the same hose adapter as the compression tester, are you removing the valve in the end of the adapter when doing a leak test? From what I see you should have some leakage.
