Author Topic: How to wire stock regulator?  (Read 606 times)
Offline KasparHauser
« on: August 03, 2021, 01:01:23 AM »
Hi,
I have bought a stock regulator from ebay since I am going back to AGM (previous owner switched to lithium and therefore got a new rec/reg as well).
I can't seem to find any information on how to wire the regulator though.
I should have three wires: white, green, black. The three pins on the regulator are marked with "E", "F", and "I". One letter on each.
Which wire should go on which pin?
Thank you!
Re: How to wire stock regulator?
« Reply #1 on: August 03, 2021, 01:07:17 AM »
There should be some coloured tape on the lid of the reg with the colours on. If nobody chips in before i get into my garage i will look for you
« Reply #2 on: August 03, 2021, 03:12:16 AM »
Of course... I thought that was some kind of flag or some other decoration.
Well that certainly clears it up. Sometimes it's simpler than you think! Thank you so much!
Offline Deltarider
  • First round...
« Reply #3 on: August 03, 2021, 05:51:58 AM »
Green is ground, black is PLUS and white goes to the dynamo.
If you will pardon my German: möchtest du ein solcher Reiter werden, wie dein Vater gewesen ist?
Have you ever seen that Werner Herzog film?
CB500K2-ED Excel black
« Reply #4 on: August 03, 2021, 09:05:17 AM »
I have not! Is it any good?
Offline Deltarider
  • First round...
« Reply #5 on: August 05, 2021, 07:17:19 AM »
So and so. We have shown that film several times in a film art house, long before Werner Herzog became well known and his films made it to the main stream cinemas.
