just on a side note im not sure if also those air bleeds in the bodies changed Loyd?
Hi Dave!
In my encounters:
The 022a came with hollow tipped pilot screws. US K models 1974 through 1975.
The 069a came with solid tipped pilot screws. US F models 1975 through 1977.
The 087a found on 1976 K2 carbs I acquired had all the same internal parts and settings as the 022a, except it had solid tipped pilot screws. I could find no other differences the carb bodies among all the samples I have.
I must mention that although I was told the 087a carb bank I acquired was original from a member here, it came separate from a bike, and I was unable to verify it unconditionally as unmolested. But, it makes some logical sense on the timeline march toward EPA acceptance criteria taking effect in 1978.
I have a spec sheet that specifies the pilot screw tip taper changed from the 022a to the 069a (hollow to solid tipped). I am unable to verify if the body’s seats were correspondent. If so, the bodies would indeed be technically different, too. But, I wouldn’t expect any noticeable change in functionality, apart from standard pilot screw setting among them.
Lastly, the Honda shop booklet I have shows the same carb settings for all CB 550 models for K0,K1, and K2, and different settings for the F models.
For completeness, there is also a 649 stamped Keihin carb body, which is reportedly found in Europe and perhaps Canada, whose settings and specs. are unknown to me, and samples of which I have never seen. These were paired with a different air filter top with a smaller inlet than those found in all US models. I’ve only seen pictures of this, and have no first hand experience. All info I have about these carbs came from this forum. I suspect there must be some other change, perhaps in the carb body, to correspond with the smaller air inlet. But, I have no credible source to confirm that hypothesis, only extrapolation about how these carbs must obey physical laws.
Cheers!
