Author Topic: Cheers CB750K7, from Fort Collins CO  (Read 1693 times)
Offline beerme351
« on: August 15, 2021, 05:36:25 PM »
Hello Everyone,
Long time tinker/garage engineer, short time lurker (Joined in April), fan of fermented beverages, and have dove head first into a neglected old girl CB750K7 for a full rebuild.  It appears she has just over 17,000 original miles, frame is straight, and most components are present.  I'm in no hurry, so I plan to go through every bit of this old bike...before before I put her back on the road.
Purchased HondaMans book...and an old Chilton book.  Extremely impressed with MY CB750 book, getting the engine out was no problem at all, with all of Mark's pointers.  Found two issues, a seized oil filter bolt, and an oil pan full of gas.
Engine is out and now debating next steps...if I should do the engine rebuild or hire a shop to do so.
« Last Edit: August 16, 2021, 08:09:45 PM by beerme351 »
Offline goodtryer
Re: Cheers CB750K7, from Fort Collins CO
« Reply #1 on: August 15, 2021, 05:46:51 PM »
Howdy!
Man, that oil filter bolt is a mess!
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #2 on: August 15, 2021, 05:50:36 PM »
Welcome from NE MN,
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline beerme351
« Reply #3 on: August 15, 2021, 05:55:29 PM »
Howdy!
Yep, gonna need a new one of those and housing.  Tried everything I know of, vise grips, pipe wrench, chisel on wide part of head flange...and lots of heat on all of the above.
« Reply #4 on: August 15, 2021, 06:45:43 PM »
Welcome from Southern Arizona
Offline goodtryer
« Reply #5 on: August 15, 2021, 09:23:23 PM »
maybe weld a nut onto it?
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline tool14
« Reply #6 on: August 16, 2021, 04:10:08 AM »
welcome aboard
Offline rocket johnny
« Reply #7 on: August 16, 2021, 07:00:42 AM »
welcome from the western slope .    check with mark /  honda man as looks like he is doing engines .  your close enough to deliver in person
« Reply #8 on: August 16, 2021, 09:03:04 AM »
Welcome from The Springs
« Reply #9 on: August 16, 2021, 09:11:09 AM »
Hello Everyone,
Purchased Oldmanhonda's book...and an old Chilton book.  Extremely impressed with MY CB750 book, getting the engine out was no problem at all, with all of Mark's pointers.  Found two issues, a seized oil filter bolt, and an oil pan full of gas.
If you hire it out, maybe drop it off at my place? I'm in Lakewood.
Offline beerme351
« Reply #10 on: August 16, 2021, 08:11:56 PM »
Hello Everyone,
Heck yeah, might have to take you up on that.  Too good to pass up. I'll shoot you a message.
Offline newday777
« Reply #11 on: September 15, 2021, 03:37:59 AM »
Welcome aboard. That should clean up pretty easy...... Did you get that filter bolt out?
You'll be in good hands having Mark do the refresh.
Stu
My current rides
Prior bikes....
« Reply #12 on: September 15, 2021, 09:20:28 AM »
Looking thru my stuff...I also found 3 of the K7 mufflers (and a 4th one of the #3 pipe) still in my garage, in case one of yours is rusted?
« Reply #13 on: September 15, 2021, 11:41:05 AM »
Welcome from Texas.  The tank appears to be an F model.
There are two sizes of oil filter bolt heads, source the larger one, I believe it is 17mm.
Offline beerme351
« Reply #14 on: September 16, 2021, 06:12:17 AM »
I did...but, ehhh, I'm going to need a new Oil filter housing and bolt :)
Offline beerme351
« Reply #15 on: September 16, 2021, 06:16:06 AM »
Nice! I'll have to check it out.  I can commit to late-October, when I'll have finances ready to start the rebuild.  Let me know what your schedule is looking like.
Offline beerme351
« Reply #16 on: September 16, 2021, 06:18:57 AM »
Thanks for the tip!  It is a F model tank, I purchased the bike from a motorcycle shop estate auction and am guessing they had intentions of a rebuild.  However the bottom of the tank is pretty rusted...for fun, I'm going to give it a go on cutting out rust and welding a custom plate in place.  If it doesn't work out I did score a K tank for $40 in immaculate condition, as a back up.
« Reply #17 on: September 16, 2021, 05:13:29 PM »
I have a K7 tank, too. I think the petcock still works, but the door on top is missing. I used to use it for running engines after rebuild, but now I have an IV-type bottle, courtesy of a member here, that if much easier to use.
