For a 1978 CB750F. I'm using a Carbtune to balance the carbs and it is showing no vacuum at idle and very litle at higher rpms. I have the original carb manifolds and they are not rock hard. I have installed the correct way I believe. The carbs have been gone through. The engine will start with full choke but dies when I give it a bit of throttle. I can very gently increase the revs and it will keep running. I'm thinking new manifolds and accelerator pump diaghram piece. Any other hints you may have? Thanks, Cliff.
