Author Topic: Bonneville Bound  (Read 20976 times)
Online BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Bonneville Bound
« Reply #100 on: February 03, 2025, 09:51:02 AM »
Prize Packages are on the way
Offline richmagee7
« Reply #101 on: February 03, 2025, 01:13:41 PM »
Roger that Bombermann,
I should work on my bike for next year.  I mean this year.   But it's always a last-minute thrash so I might as well wait till the last minute, right.  ;D
Rich
  • Holy Cow! I'm a
« Reply #102 on: February 03, 2025, 02:17:38 PM »
If it gets it done it gets it done 🤷🏼‍♂️
Lets just say, the tax return is already spent
125+ is the goal.
Offline richmagee7
« Reply #103 on: August 19, 2025, 03:10:29 PM »
Bonneville bound again.  Heading out tomorrow the 20th, should arrive Friday afternoon and setup pits. Bike was ready a few weeks ago which is worrisome since typically it's a thrash till the last minute.  This just feels wrong.
Last year we bumped up three records racing modified classic 500 classes but all in fourth gear, MPS-CG, MPS-CF, and M-CF.  Shifting into fifth actually lost rpms slowly.   Since then I've picked up a close ratio 5th gear from Dresda500 on the forum here, dropped that into the bike.  Also picked up a 36 and 37 rear sprocket.  I only had smaller sprockets last year because, well we want to go fast right.   Our best run was 123+ but we didn't try to compete in Modified classic gas M-CG since that record was 128 and we weren't going to get there.   So we have our sights set on that this year, get fifth gear to pull and run over 128, would love to hit 130.  Still can't get my AFR gauge to act right, I may have screwed the sensor up with leaded additives.
Anyway, the promaster van is loaded and the wife is ready to hit the casinos.
Rich
Offline denward17
« Reply #104 on: August 19, 2025, 03:46:40 PM »
Looking good!
Good Luck Rich!
Online scottly
« Reply #105 on: August 19, 2025, 09:55:46 PM »
What was your RPM, was it in 4th gear, and what sprockets were you running? The tach is your best guide for gearing: if the best speed has the RPM higher than the engine peak horsepower RPM, it means you need to go to taller gearing, and if the engine won't pull to the peak RPM like you experienced with 5th gear, you need to go to lower gearing. It doesn't matter which combo of sprockets and gears put the engine in the sweet spot. ;) Take every sprocket you have. Did you ever get the bike on a dyno?
Good luck, and keep us posted.
« Reply #106 on: August 20, 2025, 07:13:07 AM »
Good luck Rich!  Keep us posted...
Offline richmagee7
« Reply #107 on: August 22, 2025, 03:46:58 PM »
Thanks guys.  I'll have to go to my notes Scotty.
Online scottly
« Reply #108 on: August 22, 2025, 04:35:25 PM »
Found it... ;D
Scottly,
Probably went into the measured mile at 10,500, maybe crept up to 10,700 by the exit.  I was hitting 12k in 2nd and 3rd.  Planned to run go pro which I always have capturing the tach also but had battery problems, got busy with just trying to get out on track and left the gopro alone.  Sometimes I find the gopro's memory is better than mine.  But the jetting change from 105s to 100s definitely picked up power and revs on the last two runs.  Headwinds and tailwinds have quite the effect also.
Rich
« Reply #109 on: August 22, 2025, 05:02:51 PM »
Good luck, Rich!
Online scottly
« Reply #110 on: August 22, 2025, 08:19:11 PM »
Rich, what sprockets were you running in 4th? Since the bike pulled to 12K in 3rd, but only managed 10.7K in forth, I suspect the gearing was too high. I did some digging around and found a couple of reports of heavily modified 500s with a peak HP above 11K. Have you got a rear with 1 or 2 teeth more?
  • Holy Cow! I'm a
« Reply #111 on: August 22, 2025, 08:53:12 PM »
The race is on!
I'll catch up to you.  But excuse boost lag, excuse hahaha
See ya in scrut
« Reply #112 on: August 23, 2025, 08:43:12 AM »
Good luck guys!
« Reply #113 on: August 23, 2025, 10:16:07 AM »
  I've cleaned an O2 sensor by soaking it in no lead gas, but it's best to replace. There are parts store equivalents if you research it a little.
  I bought a clone bosch O2 sensor for cheap on ebay, the box says germany but the package shipped from china. Have not tried it yet, it was more a $30 research deal just to see how good the clone is. The box is perfect, I haven't used the part yet.
« Reply #114 on: August 23, 2025, 12:49:18 PM »
Good luck guys. Kick some ass. I won't be there to bother you but Dennis will be there in case you need some help.
Be safe.
Online scottly
« Reply #115 on: August 23, 2025, 12:56:36 PM »
Is Dennis racing?
« Reply #116 on: August 23, 2025, 01:11:28 PM »
Is Dennis racing?
Not unless he changed his mind
Online scottly
« Reply #117 on: August 23, 2025, 07:25:00 PM »
Offline richmagee7
« Reply #118 on: August 23, 2025, 09:49:45 PM »
Passed tech.  Thanks Bombermann, spend that twenty wisely, wink, wink, nod, nod.
Scotty, 34 rear last year, but I now have a 36 and a 37 in the arsenal.
Saw Dennis, chatted a bit, he's not racing.
Can't hurt to try and clean the sensor Don, but one has been loaned to me in the meantime.
Online scottly
« Reply #119 on: August 23, 2025, 10:04:20 PM »
Start with the 36. ;)
« Reply #120 on: August 24, 2025, 10:28:55 AM »
 Good on the new sensor, you have a limited time to race so make it count.
  • Holy Cow! I'm a
« Reply #121 on: August 24, 2025, 10:02:17 PM »
to
Hahaha thanks for photographing my good side.
Offline richmagee7
« Reply #122 on: August 26, 2025, 06:13:45 AM »
Let it idle too long waiting for first run, quit just past the start.  Dennis helped me get back to the pits.  Changed plugs. Made a run in afternoon.  117 into 11mph headwind.  Hit 12k easy in 2nd, 3rd with 17-36 gears, made it to 11k in 4th, shifted.  Rpms went to 10k but it did pull up to about 10.5 or 10.7.   Rained yesterday,  no racing.  Switched gearing to 18-37. Heading out hotel now, Tuesday am.
Online scottly
« Reply #123 on: August 26, 2025, 09:30:26 PM »
  • Holy Cow! I'm a
« Reply #124 on: September 01, 2025, 07:00:32 AM »
What a wild week!
The struggles for nearly everyone.
