Author Topic: Head gasket or cam tower pucks?  (Read 1128 times)
Offline fxef79
« on: August 28, 2021, 03:47:25 PM »
Based on what I see here, I’m leaning towards head gasket. But I’m interested to hear other more experienced thoughts.
Offline fxef79
Re: Head gasket or cam tower pucks?
« Reply #1 on: August 28, 2021, 03:47:55 PM »
« Reply #2 on: August 28, 2021, 04:16:32 PM »
Pucks leak like that on 750...
« Reply #3 on: August 28, 2021, 05:00:50 PM »
Do a compression test if you suspect a head gasket.  But, if it checks good, I don't think it does much to keep in the oil. Pucks, o rings, seals, etc. contain the oil, AFAIK.  Of course, to change some of those the head must come off.
« Reply #4 on: August 29, 2021, 01:40:41 AM »
Is this on a 750??????????????? Ya gotta tell us what yer workn on when asking a question.
If it's a 750??? Yes the pucks are the usual cause of oil in the fins.
Offline fxef79
« Reply #5 on: August 29, 2021, 06:19:35 AM »
Sorry about that. Yes it’s a 750 K8. (!!!!!!!!!!!!) :)
Offline fxef79
« Reply #6 on: August 29, 2021, 06:32:14 AM »
I was questioning whether it was pucks only because wouldn’t I see the oil coming out on the top of the lowest fin of the head, then spilling over onto the cylinder fins below it?  What I see (at least on one side) is zero oil on the head fins.
« Reply #7 on: August 29, 2021, 08:50:04 AM »
 There are areas inside the fins that let oil flow down to the cylinder top.
   I've had luck finding a leak on big block chevys just blowing into the vent hose and listen or spray some soapy water. On a cb750  you may need to plug the oil tank vent too. (Finger over the hose)
  The time I told my buddy at the track this he was sure I'd be making a video to embarrass him on  youtube. I had to walk away before he would try it but they did find the distributor gasket leaking vacuum which allowed the vacuum pump to suck oil.
« Last Edit: August 29, 2021, 08:56:20 AM by Don R »
« Reply #8 on: August 29, 2021, 12:06:00 PM »
 If its the pucks for sure then the cam and cam towers would need to come out but the head can stay on. Fun part is the engine has to be out also unless you have a frame kit.
Offline fxef79
« Reply #9 on: August 29, 2021, 12:49:20 PM »
Plenty of room on this frame.
Offline fxef79
« Reply #10 on: August 29, 2021, 12:51:00 PM »
Guess I’ll be pulling the cam and towers then.
« Reply #11 on: August 29, 2021, 08:21:02 PM »
while all that stuff is out of the way, I will do a cylinder head re-torque and have had good success making these things oil tight again.  Sometimes bikes that have been sitting a long time will leak or not intermittenly.  It usually takes 5 or 6 rides of full operating temp for them to decide which way they wanna go.
Online jonda500
« Reply #12 on: September 01, 2021, 07:50:05 PM »
+1  couldn't have said it any better!
John
A starter clutch thread:
