Author Topic: First time decking heads and barrel and a few ?  (Read 748 times)
Offline gbal06
« on: August 30, 2021, 08:24:29 AM »
I am sending my cb550k head and barrels to be decked by Cycle X.  I have never done this before and really don't know what questions to ask or the"musts" When doing them.  What do you guys recommend?  Will the oil passages on top of the barrels need to be bored down? What size head gasket will I need, does it effect the performance of the bike, etc.  Thank you
Offline Bodi
Re: First time decking heads and barrel and a few ?
« Reply #1 on: August 30, 2021, 08:39:13 AM »
Assume there's very little warp in the barrels, the head is usually what warps and not much at that... remove the minimum needed to get them flat, no more. Ask to be told how much was cut from both. It's likely to be only a few thousandths of an inch. That won't affect the seal bores. Head gasket - original was pretty thin, and all current head gaskets are thicker. May be asbestos or other HS related? That can cause leaking at the oil feed holes as the seals assume the thinner original gasket. I do not have a solution for that yet. With a typical head desking to remove warp, head gasket thickness doesn't matter.
If you're decking to increase compression ratio this is a totally different matter. The problem is valve clearance, and increasing head or base gasket thickness to get more clearance just cancels the gain from decking.
Offline gbal06
« Reply #2 on: August 30, 2021, 01:11:44 PM »
I am doing it because I have a leak around the head gasket no matter how many different gaskets I use.  I torque correctly wait a day torque again, wait until the value is constant without anymore torquing.I was more curious about if the performance changes.  Not really a big deal for me since this is just a daily commuter.  I have never had anything decked so I wasn't 't sure what to ask and to look for.
Offline samm_j2
« Reply #3 on: September 03, 2021, 09:17:50 PM »
Ken at cycle x is great and loves to talk bikes. Ask him any and all your questions. He is very knowledgeable. I have a great time on the phone with him and end up learning a lot. He will take great care of you and help you get it right.
« Reply #4 on: September 04, 2021, 01:31:32 AM »
if its just an oil weep be sure it aint from those cam end o rings,if it aint blowing head gaskets having it decked seems a bit extreme?also look at those bolts n washers on the end cap bracket,i throw the aluminium ones away and use copper top and bottom of that bolt,ive had a LOT of these motors in all conditions and never even looked at head milling,ive had rebores etc,look close at those pucks that form a seal over the head bolts?also the o ring for the oil gallery supplied in new sets is sometimes too thin?i also like to champher the head feed hole.
« Last Edit: September 04, 2021, 01:35:54 AM by dave500 »
« Reply #5 on: September 04, 2021, 09:13:59 AM »
HondaMan has mentioned the larger orings needed for the MLS or other head gaskets.
PM him or search for it using Google with forums.sohc4.net site specified...
