Author Topic: RE: F'nK project bike.  (Read 8565 times)
Online Don R
Re: RE: F'nK n'F project bikes.
« Reply #75 on: September 29, 2022, 12:29:57 PM »
 Economy right controls may not have a screw and button retainer to hold the switch spring and starter button in.
 Just FYI.
Online Don R
« Reply #76 on: September 30, 2022, 05:33:12 PM »
 I grabbed this M'Fer by its throttle this morning, I used an old cable I found for the pull and the new push which is correct. Then I studied the parts that fell out of the starter switch, re-assembled them in a way that made sense considering it's a two wire start button, connected a ground that it didn't have before when it was working and it now starts the first time every time. I found a broken wire connector in the headlight bucket for the left turn signal indicator light and made up a male x female x female. It's working fine now.
 The only thing left is the neutral light which is either always on or always off with no apparent reason. I'll pull the switch and clean it. The Goldwing ones get carboned up and stay on, usually dimmer than when in actually Neutral.
Online Don R
« Reply #77 on: September 30, 2022, 08:05:09 PM »
 I'm thinking flat or satin black and gold pin stripes. The gold tape stripes I had to practice with were all so old, the sticky was gone. I was thinking of using fineline masking tape to assist making a paint pinstripe pulled by hand. I may not be able to pull it off but it's worth a try.
Online Don R
Re: RE: F'nK n'F project bikes. (Now it's just F) F'nK awaits a teardown
« Reply #78 on: October 14, 2022, 02:13:31 PM »
  I went with an old antares red over original yellow tank and tail I've had for a long time. I'll have two more F tanks to sell also.
« Last Edit: October 21, 2022, 10:25:45 PM by Don R »
Online Don R
« Reply #79 on: October 21, 2022, 04:27:37 PM »
  I took the F on a mile long test ride, the headlight turns off when I turn left but comes back on when I turn back. Seems legit. The rear disc brake drug a bit but since it got bled again, it seems to brake and release.  The newly softened rubber velocity stacks are miscellaneous sizes and didn't go on, so I rode without the air box.
  The tank nut is seeping at the petcock so I drained the fuel back out. (Used seals)
  I think the headlight problem must be the green wire in the headlight bucket. It goes on and off when turning both on high and low beam so it must be the ground. A PO had used a few large size bullet connectors and  those sockets are stretched out a bit. I'm not very good at re-sizing them.  I got some two and three way connectors with my order of vintage connections so it should be an easy fix.
   This thing is starting to remind me of the 76F I sold to buy sandcast parts.
« Last Edit: October 22, 2022, 11:36:54 AM by Don R »
Online Don R
Re: RE: F'nK n'F project bikes. (Now it's just the F1)
« Reply #80 on: November 03, 2022, 01:11:01 PM »
 I cleaned up another neutral switch for the f but couldn't get it to work. I realized it wasn't seating due to the hard o ring. I tried the old one no good either, finally read up on it and measured an o ring out of the harbor freight kit. It measured a little small but popped in like it's snug and now the switch works properly. Hurray!
  We'll see if it leaks now, the rear brake is dragging when pumped up but if I bleed it the pistons retract. I assume that means it's the M/C. I'll try bleeding and flushing again.
  I'm going to try the same trick on the petcock to tank nipple and see if I can make it seal up.
« Last Edit: November 03, 2022, 01:12:50 PM by Don R »
Online Don R
« Reply #81 on: November 03, 2022, 08:21:32 PM »
 The petcock sealed up and I cut a timing advancer spring, now the idle doesn't surge but the timing was waaaay off. I dialed it back and now it cranks easier. I'll need to spend some time re-timing and checking the dwell.
 The rear brake has me concerned, there are no kits for the M/C I'll flush it again and hopefully any gunk that's in there shakes loose. I emptied the reservoir before I flushed it so only clean fluid would go in. I also have another 76 disc brake kit so if I find parts I'll get a set.
 Edit, The gl1000 rear caliper kit works, I re-posted a thread on it.
« Last Edit: November 03, 2022, 09:13:53 PM by Don R »
Online Don R
« Reply #82 on: November 04, 2022, 03:52:15 PM »
 I siphoned the brake fluid again, sprayed brake clean inside and scrubbed it with scotchbrite. I re-filled and bled it a few times, it's working like new so far. I took it for a ride, it releases good so I'm taking a wait and see approach.
 The carb rubbers should be here in a couple days so then I can pop the airbox on. I really like these F's.  The front end feels heavy in turns, I need to check the neck bearings.
« Last Edit: November 05, 2022, 01:02:26 AM by Don R »
Online Don R
« Reply #83 on: January 01, 2023, 04:25:56 PM »
 The airbox top is on, everything is working. I'm missing the hollow bolt for the bottom of the airbox. Fudge. I'll borrow the bottom off of the F'nK it needs trans work anyway. It is getting advertised on marketplace soon.
 Now, where did I put those emblems?
Online Don R
« Reply #84 on: January 03, 2023, 03:40:47 PM »
 This is the former basket case that has a lost basket. It would be a great bike for someone to finish a restomoderation.  The neutral safety switch drips and is a little sluggish. It lights when the engine is running.
« Last Edit: January 03, 2023, 03:43:23 PM by Don R »
« Reply #85 on: January 03, 2023, 03:51:28 PM »
Don,is that one a full 'F Super Sport', 410 engine ?
Online Don R
« Reply #86 on: January 04, 2023, 08:12:24 AM »
 It's the F1 with the 392 engine which may be the best all around SOHC4 engine, as fast as the sandcast without the early problems or the 410's soft valve guides.
Online Don R
« Reply #87 on: January 11, 2023, 12:26:33 PM »
 I have a pending sale on the F1, the 77 F'nK still needs 5th gear fixed. I may just swap in a different 392 type engine and keep the 77K motor for the big chamber head.
Online Don R
Re: RE: F'nK n'F project bikes. F1 pending, FnK to go.
« Reply #88 on: January 13, 2023, 03:36:31 PM »
 F1 orange tank. Actually looks better than the pics, I sanded some of the excessive overspray off, the black looked like rust but had orange paint under it.
Online Don R
« Reply #89 on: January 13, 2023, 03:42:48 PM »
  77 or 78F
Online Don R
Re: RE: F'nK n'F project bikes. F1 no longer pending, FnK to go.
« Reply #90 on: January 14, 2023, 11:36:38 AM »
 I believe the buyers wife found out. He forgot to Venmo the deposit.
 Deposit received 76F sold.
« Last Edit: January 14, 2023, 08:18:48 PM by Don R »
Online Don R
Re: RE: F'nK n'F project bikes. F1 sold FnK to go.
« Reply #91 on: February 01, 2023, 01:16:11 PM »
 The buyer is coming to get it tomorrow, I even talked him into taking a windjammer kit too.
Online Don R
« Reply #92 on: February 02, 2023, 07:54:59 PM »
 The F1 has an enthusiastic owner, he's wondering how long until his wife finds out. He took a windjammer because it was free, has already texted asking about what oil I used.
 The plan for the F'nK is to trade it for shop credit at a machine shop.
« Reply #93 on: February 03, 2023, 11:51:14 AM »
Nice start to February! Congrats.
Online Don R
« Reply #94 on: February 03, 2023, 07:47:31 PM »
 The added floor space was so awesome I took a picture of it.
Online Don R
« Reply #95 on: May 02, 2023, 12:37:54 PM »
  I'm really close to a part out of the f'nK. I have to remember that it would make open floor space if it leaves intact. It does everything well except stay in 5th gear.
Online Don R
Re: RE: F'nK project bike.
« Reply #96 on: September 23, 2023, 02:26:12 PM »
 Today I removed the F part from the F'nK I guess that makes it be an F'n K. I'm going to try the A rear fender and see what I have for a grab bar to get turn signals back on it. I have a couple Yamaha turn signals that are the same thread that holds the rear fender to the frame. They might work with or without a grab bar.
