Author Topic: Clutch cable routing  (Read 1526 times)
Offline _mark
« on: September 23, 2021, 04:02:07 AM »
Hi guys.
Is it normal that the clutch cable has this route (near the exhaust) and that I'm fully turning on the left, the cable is slightly pulled? Thanks an Regards.
Re: Clutch cable routing
« Reply #1 on: September 23, 2021, 08:01:44 AM »
 It does run down the front of that frame tube. Is it a new cable ? Maybe if you measure it someone can compare the length to a known good one.Might be too short. Bike looks like a 1971.
« Last Edit: September 23, 2021, 08:07:02 AM by ekpent »
Online Kevin D
  • SE Michigan
« Reply #2 on: September 23, 2021, 09:27:26 AM »
I have an old one in the garage, think I got the part number too… gotta move the car to get at the box, but will do after other chores.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Online Kevin D
  • SE Michigan
« Reply #3 on: September 23, 2021, 10:18:48 AM »
This is the original cable, measures 52 3/4”, updated part #22870-410-000, covers a few models.
It was sitting right on top of the old parts box.
This original cable never failed, and did 45? years of service. But I removed the bars one day and saw these strands unraveled from the bundle. Ordered the new one pronto. This old cable will work just fine in a jam.
Is that not a USA bike? Without the ID plate?
Italy…buongiorno!
« Last Edit: September 23, 2021, 10:21:37 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #4 on: September 23, 2021, 04:16:14 PM »
Italy…buongiorno!
It has a Non-U.S. plate....  Buongiorno a tutti!
« Reply #5 on: September 23, 2021, 06:04:21 PM »
 The handlebars appear to be fairly low like euro bars, not the u.s. taller ones.  The cables for euro bars or cb500 are a bit shorter.
